Product
HP OfficeJet Pro 8728 Printer
Quicklinx: C75SWS00 Mfr#: T0G54A#ABU
Key features:
  • Do everything with print, scan, copy and fax functions
  • Enjoy professional results at half the cost
  • Print wirelessly using Apple AirPrint and Google Cloud Print
The OfficeJet Pro 8728 All-in-One printer handles any task from printing and copying to faxing and scanning, making it ideal for handling any kind of creative or office project.
Print professional quality prints at 50% less cost per page of laser printers with fast double-sided printing and scanning performance. The OfficeJet Pro 8728 even uses less energy than lasers to save you time and money.
Print wirelessly with Apple AirPrint and Google Cloud Print
The OfficeJet Pro 8728 works with Apple AirPrint and Google Cloud Print Print, allowing you to print from anywhere using your smartphone or tablet without having to go near a desktop.
HP OfficeJet Pro 8728 All-in-One Wireless Inkjet Printer, Save up to 50% on ink compared to a colour laser printer, WiFi / Apple AirPrint / Google Cloud Print, Colour print / copy / scan / fax, Automatic double-sided printing, 4800 x 1200 dpi
  • Affordable, professional color
    Print many pages with high-yield ink cartridges. Manage your budget with professional-quality color at less cost per page. Save on ink and never run out. Print color or black-and-white for the same value. Professional-quality prints for less per page. Save even more with HP Instant Ink.
  • Innovative design for superb office productivity
    Print more and reload less. Increase paper capacity with a second paper tray. Speed through print jobs, using super-fast two-sided printing. Breeze through multipage documents with two-sided scanning and a 50-page automatic document feeder. Advanced design delivers laser-like paper handling and super-fast print speeds.
  • Mobile printing, that keeps your business covered
    Help protect information and access to confidential print jobs with HP JetAdvantage Private Print. Print with just a touch of your NFC-enabled mobile device to the printer - no company network needed. Print directly from your mobile device without accessing the company network, from anywhere in the office. Easily print documents, photos, and more from a variety of smartphones and tablets.
HP Officejet Pro 8728 All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English / United Kingdom
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 37 ppm (mono) / up to 37 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, photo paper, thick paper, light-weight paper, glossy paper, matte paper
Standard Media Capacity
250 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, fax to e-mail
AC 120/230 V (50/60Hz)
49.95 cm x 44.97 cm x 33.91 cm
15.01 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 2000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Caller ID
Broadcast Transmission
20 stations
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, Distinctive Ring Detection (DRD), delayed sending, fax archiving
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
Borderless Photo Sizes
A4 (210 x 297 mm)
250 sheets
150 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 24 ppm (A4) - B/W (ISO) , Printing: up to 20 ppm (A4) - colour (ISO) , Printing: up to 37 ppm (A4) - B/W draft , Printing: up to 24 ppm (A4) - B/W normal , Printing: up to 37 ppm (A4) - colour draft , Printing: up to 20 ppm (A4) - colour normal , Copying: up to 22 ppm (A4) - B/W (ISO) , Copying: up to 16 ppm (A4) - colour (ISO) , Copying: up to 37 ppm (A4) - B/W draft , Copying: up to 37 ppm (A4) - colour draft , Scanning: up to 17 ppm (A4) - B/W , Scanning: up to 8 ppm (A4) - colour , Scanning: up to 6 ppm - B/W duplex , Scanning: up to 4 ppm - colour duplex
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, Apple Bonjour, TLS, 802.1x, ARP, Wi-Fi Direct
Operating System Support
Linux, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits)
Software Included
Drivers & Utilities, HP Web Jetadmin
32 Watt
Power Consumption Standby
6.7 Watt
Power Consumption Sleep
1.3 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 745 pages - HP 953 , 1 x Cartridge (cyan) - HP 953 , 1 x Cartridge (magenta) - HP 953 , 1 x Cartridge (yellow) - HP 953
ENERGY STAR Certified
Limited warranty - 1 year
49.95 cm
44.97 cm
33.91 cm
15.01 kg
Shipping Width
58.3 cm
Shipping Depth
39.3 cm
Shipping Height
61.2 cm
Shipping Weight
18.51 kg
Sound Emission
60 dBA (operating)
15 °C
25 - 75%
