HP OfficeJet Pro 8725 AIO Colour InkJet MFP
Quicklinx: C4NYWS00 Mfr#: K7S34A#ABU
Satisfy modern office demands with HP Print Forward Design. Manage costs with affordable, professional-quality colour.[1] Stay productive and reduce paper use with blazing-fast two-sided printing from a printer made for high-volume offices.
  • Colour Printer - Perfect for Home use
  • Print, Scan, Copy & Fax
  • Paper Size - A4
  • Connectivity - Wireless, AirPrint, Network, USB
  • Up to 30,000 pages
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Experience revolutionary HP Print Forward Design. Get high speeds for two-sided print and scan jobs with laser-like paper handling, and preserve real estate with space-saving design. Print longer without reloading, with an optional second paper tray.
Keep business moving from anywhere in the office. Connect to devices with touch-to-print functionality.[6] Easily print when and where you need to from your smartphone, tablet, or notebook PC – and maintain privacy.
Stay productive with a large touchscreen and scan-to-network-folder-and-email capabilities that help you easily handle high-volume print jobs. Manage costs for a more efficient office with Colour Usage Control.
  • On-the-go printing with HP ePrint
    Print photos, documents, and more when you're on the go, using HP ePrint.
  • 2-sided printing
    Allows you to print on both sides of the page, cutting your paper use by up to 50%.
  • Automatic document feeder
    Allows multiple pages to be copied or scanned at one time.
  • Colour touchscreen (printer)
    Manage jobs directly at the MFP, using the HP colour touchscreen.
  • Ethernet (printer)
    Add this device to your office Ethernet network to share with your workgroup.
  • Scan to email
    Save time by sending scanned documents or photos directly from your printer to email recipients.
HP Officejet Pro 8725 All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English / United Kingdom
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 22 ppm (mono) / up to 16 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 24 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, photo paper, thick paper, light-weight paper, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, fax to e-mail
AC 120/230 V (50/60Hz)
49.95 cm x 44.97 cm x 33.91 cm
15.01 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty with product registration
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 2000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Caller ID
Broadcast Transmission
20 stations
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, Distinctive Ring Detection (DRD), delayed sending, fax archiving
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
Borderless Photo Sizes
A4 (210 x 297 mm)
250 sheets
Max Media Capacity
500 sheets
150 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 150 sheets
Speed Details
Scanning: up to 17 ppm (A4) - B/W , Scanning: up to 8 ppm (A4) - colour , Scanning: up to 6 ppm - B/W duplex , Scanning: up to 4 ppm - colour duplex , Printing: up to 24 ppm - B/W (ISO) , Printing: up to 20 ppm - colour (ISO) , Printing: up to 37 ppm (A4) - B/W draft , Printing: up to 37 ppm (A4) - colour draft , Copying: up to 22 ppm - B/W (ISO) , Copying: up to 16 ppm - colour (ISO) , Copying: up to 37 ppm (A4) - B/W draft , Copying: up to 37 ppm (A4) - colour draft , Printing: up to 37 ppm (Letter A) - B/W draft , Printing: up to 37 ppm (Letter A) - colour draft , Copying: up to 37 ppm (Letter A) - B/W draft , Copying: up to 37 ppm (Letter A) - colour draft
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, Apple Bonjour, TLS, 802.1x, ARP, Wi-Fi Direct
Operating System Support
Linux, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits)
Software Included
Drivers & Utilities, HP Web Jetadmin
32 Watt
Power Consumption Standby
6.7 Watt
Power Consumption Sleep
1.3 Watt
Phone cable
Consumables Included
1 x ink cartridge (black) - up to 745 pages - HP 953 , 1 x ink cartridge (cyan) - HP 953 , 1 x ink cartridge (magenta) - HP 953 , 1 x ink cartridge (yellow) - HP 953
ENERGY STAR Certified
Limited warranty - 3 years with product registration (within 60 days of purchase)
49.95 cm
44.97 cm
33.91 cm
15.01 kg
Shipping Width
58.3 cm
Shipping Depth
39.3 cm
Shipping Height
61.2 cm
Shipping Weight
18.51 kg
Sound Emission
60 dBA (operating)
15 °C
25 - 75%
C4NY HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
C4NY HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
