Satisfy modern office demands with HP Print Forward Design. Manage costs with affordable, professional-quality colour. Stay productive and reduce paper use with blazing-fast two-sided printing from a printer made for high-volume offices.
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door. Print colour, black & white, and photos – your cost is the same. Ink cartridges and delivery costs included in your monthly plan price. No annual fee – change or cancel plans online anytime without penalty.
Keep business moving from anywhere in the office. Connect to devices with touch-to-print functionality. Easily print when and where you need to from your smartphone, tablet, or notebook PC – and maintain privacy.
Print with just a touch of your NFC-enabled mobile device to the printer – no company network needed. Print directly from your mobile device without accessing the company network, from anywhere in the office. Easily print documents, photos, and more from a variety of smartphones and tablets. Help protect information and access to confidential print jobs with HP JetAdvantage Private Print.
Experience revolutionary HP Print Forward Design. Get high speeds for two-sided print and scan jobs with laser-like paper handling, and preserve real estate with space-saving design. Print longer without reloading, with an optional second paper tray.
Speed through print jobs, using superfast two-sided printing. Breeze through multipage documents with two-sided scanning and a 50-page automatic document feeder. Revolutionary design delivers laser-like paper handling and superfast print speeds. Print more and reload less. Increase paper capacity to 500 sheets with a second 250-sheet paper tray.
Stay productive with a large touchscreen and scan-to-network-folder-and-email capabilities that help you easily handle high-volume print jobs. Manage costs for a more efficient office with Colour Usage Control.
Easily manage print jobs directly at the printer. Just tap and swipe the 10.9-cm (4.3 inch) touchscreen. Scan digital files directly to email, network folders, and the cloud with preloaded business apps. Control colour-printing usage and costs across your organization. Support your high-volume office with a device designed to print 30,000 pages per month for up to five users.
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%. -
Automatic document feeder
Allows multiple pages to be copied or scanned at one time. -
Colour touchscreen (printer)
Manage jobs directly at the MFP, using the HP colour touchscreen. -
Ethernet (printer)
Add this device to your office Ethernet network to share with your workgroup. -
Scan to email
Save time by sending scanned documents or photos directly from your printer to email recipients.
- HP Officejet Pro 8720 All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2000 pages
- Max Copying Speed
- Up to 22 ppm (mono) / up to 16 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 24 ppm (mono) / up to 20 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 4.3"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, recycled paper, photo paper, thick paper, card stock, light-weight paper, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, fax to e-mail, HP Instant Ink
- Power
- AC 120/230 V (50/60Hz)
- 49.95 cm x 53.01 cm x 33.91 cm
- 15.01 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 250 - 2000 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Collation copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3e, PDF, PCL 3 GUI
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- Fax Printing Speed
- Up to 15 ppm
- Fax Printing Resolution
- 203 x 196 dpi
- PC Faxing
Fax Machine Features
- Caller ID
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax archiving
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
- Borderless Photo Sizes
- A4 (210 x 297 mm), 215.9 x 279.4 mm
- 250 sheets
- 500 sheets
- 150 sheets
- ADF - 50 sheets - 216 x 356 mm , Input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) , Output tray - 150 sheets
- Speed Details
- Scanning: up to 23 ipm - B/W duplex , Scanning: up to 12 ipm - colour duplex , Scanning: up to 17 ipm - B/W , Scanning: up to 8 ipm - colour , Printing: up to 24 ppm - B/W (ISO) , Printing: up to 20 ppm - colour (ISO) , Printing: up to 37 ppm (A4) - B/W draft , Printing: up to 37 ppm (A4) - colour draft , Copying: up to 37 ppm (A4) - B/W draft , Copying: up to 37 ppm (A4) - colour draft , Copying: up to 22 ppm - B/W (ISO) , Copying: up to 16 ppm - colour (ISO) , Copying: up to 37 ppm (Letter A) - B/W draft , Copying: up to 37 ppm (Letter A) - colour draft , Printing: up to 37 ppm (Letter A) - B/W draft , Printing: up to 37 ppm (Letter A) - colour draft
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Operating System Support
- Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition
- Software Included
- Drivers & Utilities, I.R.I.S. OCR, HP Web Jetadmin, HP Participation Study
- Voltage Required
- 35 Watt
- Power Consumption Standby
- 6.7 Watt
- Power Consumption Sleep
- 1.3 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 800 pages - HP 952 , 1 x ink cartridge (cyan) - up to 490 pages - HP 952 , 1 x ink cartridge (magenta) - up to 490 pages - HP 952 , 1 x ink cartridge (yellow) - up to 490 pages - HP 952
- ENERGY STAR Certified
- 49.95 cm
- 53.01 cm
- 33.91 cm
- 15.01 kg
- Shipping Width
- 61.2 cm
- Shipping Depth
- 58.3 cm
- Shipping Height
- 39.3 cm
- Shipping Weight
- 18.5 kg
- Sound Emission
- 60 dBA (operating)
- 15 °C
- 32 °C
- 20 - 80%
