Product
HP OfficeJet Pro 8715 All-in-One MFP Printer
Quicklinx: DC7GWS00 Mfr#: M9L70A#ABU
£120.36 ex VAT
£144.43 inc VAT
Stay productive and tackle high-volume jobs with print, fax, scan, and copy versatility. Save up to 70% on ink with HP Instant Ink.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
  • Save up to 70% on ink with HP Instant Ink
    Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty.
  • Remarkable value for professional, in-office colour
    Manage your budget with professional-quality colour at up to 50% less cost per page than lasers.Print up to twice as many pages with optional Original HP high-yield ink cartridges.Produce professional-quality colour and black text that's perfect for printing reports, emails, and more.Rely on Original HP ink cartridges for durable documents that are water-, fade-, and smear-resistant.
  • Everything you need to finish jobs fast
    Get more done with print, fax, scan, and copy capabilities and a 50-page automatic document feeder.Fast two-sided printing, copying, and scanning help you fly through tasks.Easily manage all your tasks and access shortcuts – just tap and swipe the 6.75-cm (2.65 inch) touchscreen.Scan digital files directly to email, network folders, and the cloud with preloaded business apps.
  • Mobile printing that keeps your business covered
    Print directly from your mobile device without accessing the company network, from anywhere in the office.Easily print documents, photos, and more from a variety of smartphones and tablets.Help protect information and access to confidential print jobs with HP JetAdvantage Private Print.
HP Officejet Pro 8715 All-in-One - multifunction printer (colour)
Multifunction printer
Fax Type
Plain paper
English / United Kingdom
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
25000 pages
Recommended Monthly Volume
250 - 1500 pages
Max Copying Speed
Up to 20 ppm (mono) / up to 14 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 18 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 dpi
Display
2.65"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, photo paper, thick paper, card stock, light-weight paper, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to folder, fax to e-mail
AC 120/230 V (50/60Hz)
49.95 cm x 40.48 cm x 33.91 cm
11.54 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty with product registration
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
25000 pages
250 - 1500 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy, collation copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Speed Dialing
20 station(s)
Caller ID
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
Borderless Photo Sizes
A4 (210 x 297 mm), 215.9 x 279.4 mm
250 sheets
Max Media Capacity
250 sheets
150 sheets
ADF - 50 sheets - 216 x 356 mm , Input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 22 ppm (A4) - B/W (ISO) , Printing: up to 18 ppm (A4) - colour (ISO) , Printing: up to 12 ipm (A4) - B/W duplex , Printing: up to 10 ipm (A4) - colour duplex , Scanning: up to 8 ipm (A4) - B/W duplex , Copying: up to 20 ppm (A4) - B/W (ISO) , Copying: up to 14 ppm (A4) - colour (ISO) , Scanning: up to 4 ipm (A4) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 2 x modem - RJ-11 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, ARP, Wi-Fi Direct
Operating System Support
Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities, HP Web Jetadmin, Dropbox, Google Drive, Microsoft DotNet
35 Watt
Power Consumption Standby
6.1 Watt
Power Consumption Sleep
1.2 Watt
Phone cable, Ethernet cable
Consumables Included
1 x Cartridge (black) - up to 745 pages - HP 953 , 1 x Cartridge (cyan) - up to 400 pages - HP 953 , 1 x Cartridge (magenta) - up to 400 pages - HP 953 , 1 x Cartridge (yellow) - up to 400 pages - HP 953
ENERGY STAR Certified
Limited warranty - 3 years with product registration (within 60 days of purchase)
49.95 cm
40.48 cm
33.91 cm
11.54 kg
Shipping Width
56.9 cm
Shipping Depth
37.7 cm
Shipping Height
49.2 cm
Shipping Weight
14.5 kg
Sound Emission
63 dBA (operating)
5 °C
25 - 75%
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Brand: HP
Price Range Ex VAT: 100 - 150
