HP OfficeJet Pro 8218 Printer
Quicklinx: CSZSWS00 Mfr#: J3P68A#A81
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: A4 (210 x 297 mm)
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Hurry, only 2 left in stock!
£108.64 ex VAT
£130.36 inc VAT
Control costs and printing practices, with affordable colour and comprehensive fleet-wide management. Print professional-quality colour and get seamless print management features. Boost efficiencies with a variety of mobile printing choices.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
Save up to 70% on ink with HP Instant Ink
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Everything you need to finish jobs fast
Stay on top of business. Complete high-volume jobs quickly and efficiently with fast two-sided printing. Easily print Microsoft® Office documents directly from your USB drive, and boost productivity with a 5.08-cm (2.0-inch) display.
Mobile printing that keeps your business covered
Keep business moving. Easily print from your smartphone, tablet, or notebook PC, with a variety of mobile printing choices.
Superior fleet control, seamless management
Get everything you need to easily manage your printing environment, from drivers to deployment to policies. With support for HP PCL 6, HP PCL 5c, and HP PS, you can expand print capabilities.
  • Save up to 70% on ink with HP Instant Ink
    Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty.
  • Everything you need to finish jobs fast
    Speed through print jobs, using fast two-sided printing.Easily print Microsoft Word and PowerPoint files, plus Adobe PDF files, directly from your USB drive.Stay productive with a 5.08-cm (2.0-inch) display with keypad that's intuitive and easy to use.Increase paper capacity to 500 sheets with the included second 250-sheet paper tray.
  • Mobile printing that keeps your business covered
    Print directly from your mobile device without accessing the company network, from anywhere in the office.Easily print documents, photos, and more from a variety of smartphones and tablets.
  • Superior fleet control, seamless management
    Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts.Easily take command of your printing environment from one central location, with HP Web Jetadmin.Make it easy for all to print with one common driver.Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager.
HP Officejet Pro 8218 - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
8.2 kg
EMEA (excluding Israel, Saudi Arabia)
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 20 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 16 ppm - color (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Preview Screen Size
2"
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 3, PCL 5C, PostScript 3, PCL 6, PCL XL, PDF
Media Type
Envelopes, plain paper, photo paper, cards, postcards
Total Media Capacity
500 sheets
Media Handling
500-sheet input tray
Recommended Monthly Volume
250 - 1500 pages
Print server
AC 120/230 V
Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
49.8 cm x 41.9 cm x 20.4 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
Status LCD
Preview Screen Size
2"
Wireless
AirPrint Enabled
1200 x 1200 dpi
2400 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Language Simulation
Media Handling
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
Borderless Photo Sizes
A4 (210 x 297 mm)
Media Weight
60 g/m² - 300 g/m²
500 sheets
Media Feeders
1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²
Max Media Capacity
500 sheets
Duty Cycle
250 - 1500 pages
Print server
Security Protocols & Features
Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
1 x USB cable
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
30 Watt
Power Consumption Stand by
3 Watt
Power Consumption Sleep
0.97 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows 7/8/8.1/10 - 1 GHz HD 2 GB , Windows Vista - 800 MHz HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 850 MB , MacOS X 10.9/10.10 - HD 1 GB
Environmental Standards
ENERGY STAR
15 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
55 dBA
49.8 cm
41.9 cm
20.4 cm
8.2 kg
Width (Shipping)
56.7 cm
Depth (Shipping)
48.7 cm
Height (Shipping)
30 cm
Weight (Shipping)
11.37 kg
Type: Printer
Wireless Capability: Wireless
Brand: HP
Price Range Ex VAT: 100 - 150
