Control costs and printing practices, with affordable colour and comprehensive fleet-wide management. Print professional-quality colour and get seamless print management features. Boost efficiencies with a variety of mobile printing choices.
Features:
- Colour Printer- Perfect for Home use
- Print Only
- Paper Size - A4
- Connectivity - AirPrint, Network, USB
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.
Print colour, black & white, and photos – your cost is the same.
Ink cartridges and delivery costs included in your monthly plan price.
No annual fee – change or cancel plans online anytime without penalty.
Stay on top of business. Complete high-volume jobs quickly and efficiently with fast two-sided printing. Easily print Microsoft® Office documents directly from your USB drive, and boost productivity with a 5.08-cm (2.0-inch) display.
Speed through print jobs, using fast two-sided printing.
Easily print Microsoft® Word and PowerPoint® files, plus Adobe® PDF files, directly from your USB drive.
Stay productive with a 5.08-cm (2.0-inch) display with keypad that’s intuitive and easy to use.
Support your high-volume office with a device designed to print 30,000 pages per month for up to five users.
Keep business moving. Easily print from your smartphone, tablet, or notebook PC, with a variety of mobile printing choices.
Print directly from your mobile device without accessing the company network, from anywhere in the office.
Easily print documents, photos, and more from a variety of smartphones and tablets.
Get everything you need to easily manage your printing environment, from drivers to deployment to policies. With support for HP PCL 6, HP PCL 5c, and HP PS, you can expand print capabilities.
Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts.
Easily take command of your printing environment from one central location, with HP Web Jetadmin.
Make it easy for all to print with one common driver.
Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager.
Save up to 70% on ink with HP Instant Ink
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty. -
Everything you need to finish jobs fast
Speed through print jobs, using fast two-sided printing.Easily print Microsoft Word and PowerPoint files, plus Adobe PDF files, directly from your USB drive.Stay productive with a 5.08-cm (2.0-inch) display with keypad that's intuitive and easy to use.Support your high-volume office with a device designed to print 30,000 pages per month for up to five users. -
Mobile printing that keeps your business covered
Print directly from your mobile device without accessing the company network, from anywhere in the office.Easily print documents, photos, and more from a variety of smartphones and tablets. -
Superior fleet control, seamless management
Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts.Easily take command of your printing environment from one central location, with HP Web Jetadmin.Make it easy for all to print with one common driver.Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager.
- HP Officejet Pro 8210 - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 8.2 kg
- Localisation
- EMEA (excluding Israel, Saudi Arabia)
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 22 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 18 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 12 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 10 ppm - colour duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Preview Screen Size
- 2"
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 3, PCL 5C, PostScript 3, PCL 6, PCL XL, PDF
- Media Type
- Envelopes, plain paper, photo paper, cards, postcards
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray
- Recommended Monthly Volume
- 250 - 1500 pages
- Networking
- Print server
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
- 3-year warranty with product registration
- 49.8 cm x 41.9 cm x 20.4 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Status LCD
- 2"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 2400 x 1200 dpi
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
- Media Handling
RAM
- 256 MB / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
- Borderless Photo Sizes
- A4 (210 x 297 mm)
- Media Weight
- 60 g/m² - 300 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²
- Max Media Capacity
- 250 sheets
Duty Cycle
- 250 - 1500 pages
- Networking
- Print server
- Wi-Fi Direct
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) - up to 1000 pages - HP 953 , 1 x ink cartridge (cyan) - up to 640 pages - HP 953 , 1 x ink cartridge (magenta) - up to 640 pages - HP 953 , 1 x ink cartridge (yellow) - up to 640 pages - HP 953
- Power Device
- Power supply - internal
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 30 Watt
- Power Consumption Stand by
- 3 Watt
- Power Consumption Sleep
- 0.97 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows 7/8/8.1/10 - 1 GHz HD 2 GB , Windows Vista - 800 MHz HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 850 MB , MacOS X 10.9/10.10 - HD 1 GB
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years with product registration
- 15 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 55 dBA
- 49.8 cm
- 41.9 cm
- 20.4 cm
- 8.2 kg
- Width (Shipping)
- 56.7 cm
- Depth (Shipping)
- 48.7 cm
- Height (Shipping)
- 30 cm
- Weight (Shipping)
- 11.37 kg
Ink (1)
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £12.47 |
Other bundles (3)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £2.27 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.13 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.80 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
C489 043379 Condition: Customer return - item has been used and shows signs of use |
£50.66 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
