Brand
HP Officejet Pro 8210 A4 printer 2400x1200dpi
Quicklinx: C489WS00 Mfr#: D9L63A#A81
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Technology: Thermal Ink-jet
Max Paper Size: A4 (210 x 297 mm)
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£102.65 ex VAT
£123.18 inc VAT
Control costs and printing practices, with affordable colour and comprehensive fleet-wide management. Print professional-quality colour and get seamless print management features. Boost efficiencies with a variety of mobile printing choices.
Features:
- Colour Printer- Perfect for Home use
- Print Only
- Paper Size - A4
- Connectivity - AirPrint, Network, USB
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
  • Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.
  • Print colour, black & white, and photos – your cost is the same.
  • Ink cartridges and delivery costs included in your monthly plan price.
  • No annual fee – change or cancel plans online anytime without penalty.
Stay on top of business. Complete high-volume jobs quickly and efficiently with fast two-sided printing. Easily print Microsoft® Office documents directly from your USB drive, and boost productivity with a 5.08-cm (2.0-inch) display.
  • Speed through print jobs, using fast two-sided printing.
  • Easily print Microsoft® Word and PowerPoint® files, plus Adobe® PDF files, directly from your USB drive.
  • Stay productive with a 5.08-cm (2.0-inch) display with keypad that’s intuitive and easy to use.
  • Support your high-volume office with a device designed to print 30,000 pages per month for up to five users.
Keep business moving. Easily print from your smartphone, tablet, or notebook PC, with a variety of mobile printing choices.
  • Print directly from your mobile device without accessing the company network, from anywhere in the office.
  • Easily print documents, photos, and more from a variety of smartphones and tablets.
Get everything you need to easily manage your printing environment, from drivers to deployment to policies. With support for HP PCL 6, HP PCL 5c, and HP PS, you can expand print capabilities.
  • Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts.
  • Easily take command of your printing environment from one central location, with HP Web Jetadmin.
  • Make it easy for all to print with one common driver.
  • Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager.
  • 2-sided printing
    Allows you to print on both sides of the page, cutting your paper use by up to 50%.
  • Unleash your printing
    Print wirelessly from your mobile device without a Wi-Fi code or password.
  • Print from virtually anywhere with HP ePrint
    Print photos, documents, and more when you're on the go, using HP ePrint.
  • Remote control for your printer
    Manage your e-all-in-one or MFP from your smartphone or tablet, using the HP All-in-One Printer Remote app.
  • Easy mobile printing from HP
    Easily print from your smartphone, tablet, and notebook at work, home, or on the go.
  • 4 individual inks
    Individual Inks - Replace only the individual ink cartridge that runs out.
HP Officejet Pro 8210 - printer - colour - ink-jet - HP Instant Ink eligible
Printer Type
Workgroup printer - ink-jet - colour
8.2 kg
EMEA (excluding Israel, Saudi Arabia)
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 22 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 18 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 12 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 10 ppm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Preview Screen Size
2"
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 3, PCL 5C, PostScript 3, PCL 6, PCL XL, PDF
Media Type
Envelopes, plain paper, photo paper, cards, postcards
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray
Recommended Monthly Volume
250 - 1500 pages
Print server
Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
3-year warranty with product registration
49.8 cm x 41.9 cm x 20.4 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
Status LCD
Preview Screen Size
2"
Wireless
AirPrint Enabled
1200 x 1200 dpi
2400 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Language Simulation
Media Handling
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
Borderless Photo Sizes
A4 (210 x 297 mm)
Media Weight
60 g/m² - 300 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²
Max Media Capacity
250 sheets
Duty Cycle
250 - 1500 pages
Print server
Security Protocols & Features
Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) - up to 1000 pages - HP 953 , 1 x ink cartridge (cyan) - up to 640 pages - HP 953 , 1 x ink cartridge (magenta) - up to 640 pages - HP 953 , 1 x ink cartridge (yellow) - up to 640 pages - HP 953
Power supply - internal
Frequency Required
50/60 Hz
30 Watt
Power Consumption Stand by
3 Watt
Power Consumption Sleep
0.97 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows 7/8/8.1/10 - 1 GHz HD 2 GB , Windows Vista - 800 MHz HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 850 MB , MacOS X 10.9/10.10 - HD 1 GB
Environmental Standards
ENERGY STAR
Limited warranty - 3 years with product registration
15 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
55 dBA
49.8 cm
41.9 cm
20.4 cm
8.2 kg
Width (Shipping)
56.7 cm
Depth (Shipping)
48.7 cm
Height (Shipping)
30 cm
Weight (Shipping)
11.37 kg
Ink (8)
C489 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £13.67
C489 HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.81
C489 HP 953XL High Yield Black Original Ink cartridge for Officejet In Stock £36.54
C489 HP 953XL High Yield Magenta Original Ink cartridge for Officeje In Stock £26.13
C489 HP 953XL High Yield Yellow Original Ink cartridge for Officejet In Stock £26.13
C489 HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £14.27
C489 HP Ink Cartridge No 957XL Black In Stock £40.61
C489 HP 953 CMYK Original INK Cartridge 4 In Stock £81.63
Other bundles (6)
C489 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £32.80
C489 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £9.05
C489 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 2 Years Shipment In Stock £16.40
C489 HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm In Stock £14.84
C489 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years In Stock £65.61
Type: Printer
Wireless Capability: Wireless
Brand: HP
