HP OfficeJet Pro 7740 AIO Printer
Quicklinx: CP0JWS00 Mfr#: G5J38A#A80
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Wireless Capability: Wireless
Max Paper Size: 297 x 431 mm
£121.65 ex VAT
£145.98 inc VAT
Print, scan, and copy in standout colour on sizes up to A3, for bold documents and presentations at up to 50% less cost per page than colour laser. Fax up to 21.6 x 35.6 cm (8.5 x 14 inches).
Dynamic security: Cartridges with non-HP chips might not work today or in the future.
Print, scan, copy and fax with ease
The OfficeJet Pro 7740 has the capability to print, scan, copy and fax documents in a wide range of sizes, making it an ideal addition to the office. With two paper trays, each capable of holding up to 250 sheets of paper, the printer also has a 35 page automatic document feeder (ADF) to save you time.
A 2.6" colour touchscreen control panel keeps you in control at all times, allowing you to select your preferred settings for each task.
Professional quality for less
Providing up to 50% lower cost per page than traditional laser printers, the OfficeJet Pro 7740 is an efficient choice for the office. It can produce water- and smear-resistant documents, as well as borderless brochure printing.
With automatic two-sided printing saving you paper, the printer can run on individual HP high-yield ink cartridges to ensure that you don't throw away useable ink.
Easy wireless printing and connectivity
The OfficeJet Pro 7740 features both built-in Ethernet and wireless connectivity, making it simple to access, print and share resources on a network. Using HP ePrint and other services such as Apple AirPrint, you can print documents remotely with ease.
You can manage your printing tasks and scans on the go using the free HP All-in-One Printer Remote mobile app, available on smart devices such as smartphones and tablets.
HP OfficeJet Pro 7740 All-in-One Wireless A3 Inkjet Printer with Fax, WiFi / Apple AirPrint / Google Cloud Print, Colour print / copy / scan / fax, Automatic double-sided printing, 4800 x 1200 dpi
  • High-impact A3 printing
    Automatic two-sided printing, fast print speeds, and an auto document feeder help ease your day.The 35-page ADF handles documents up to 21.6 x 35.6 cm, so you finish duplex jobs quickly.Tap and swipe the smartphone-style colour touchscreen for timesaving shortcuts.Increase paper capacity to 500 sheets with the included second 250-sheet paper tray.
  • Present professionally
    Create vibrant colour graphics and deep black text on a variety of papers from A4 to tabloid (A3).Produce water-, smear-, and fade-resistant prints that stand up to highlighters.Print more black text and colour pages with optional Original HP high-yield ink cartridges.Help your business stand out with borderless, double-sided marketing materials.
  • Easy mobile printing
    Easily print documents and more from your smartphones and tablets, whether Apple , Android , or Windows.Easily connect this all-in-one with wireless devices, so everyone in the office can print conveniently.Easily manage printing tasks and scan on the go with the HP All-in-One Printer Remote mobile app.Help protect information and access to confidential print jobs with HP JetAdvantage Private Print.
HP Officejet Pro 7740 All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 1500 pages
Max Copying Speed
Up to 33 ppm (mono) / up to 31 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 34 ppm (mono) / up to 34 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 dpi
Display
2.65"
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
297 x 431 mm (max)
Media Type
Plain paper, photo paper, thick paper, glossy paper, matte paper
Standard Media Capacity
250 sheets
Output Trays Capacity
75 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, automatic paper sensor
AC 120/230 V (50/60Hz)
58.4 cm x 46.69 cm x 38.33 cm
19.5 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 1500 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PCL 3, PCL XL, PCL 3 GUI
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Machine Features
Speed Dialing
100 station(s)
Colour faxing
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Max Media Size
A3
Min Media Weight
60 g/m²
Max Media Weight
105 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 130 x 180 mm, 90 x 130 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm)
Supported Envelope Sizes
US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
250 sheets
75 sheets
ADF - 35 sheets size: 76 x 127 mm - 215.9 x 355.6 mm , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets
Speed Details
Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 22 ppm (A4) - B/W normal , Printing: up to 34 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Printing: up to 18 ppm (Letter A) - colour normal , Copying: up to 33 ppm (A4) - B/W draft , Copying: up to 31 ppm (A4) - colour draft
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 2 x modem - RJ-11
Operating System Support
Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
37 Watt
Power Consumption Standby
6.5 Watt
Power Consumption Sleep
1.47 Watt
Phone cable
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
EN 61000-3-2:2006, EN 61000-3-3:2008, EN55022:2010 Class B, EN 55024:2010, CISPR 22:2008
ENERGY STAR Certified
Limited warranty - 1 year
58.4 cm
46.69 cm
38.33 cm
19.5 kg
Shipping Weight
24.45 kg
Sound Emission
65 dBA (operating)
5 °C
20 - 80%
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Brand: HP
Price Range Ex VAT: 100 - 150
