HP OfficeJet Pro 7730 Wide Format All-in-One
Quicklinx: D3ZDWS00 Mfr#: Y0S19A#A80
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Thermal Ink-jet
12 in stock
£142.58 ex VAT
£171.09 inc VAT
Get professional-quality colour that's ready for business. Easily print up to 27,9 x 43,18 cm (11 x 17 inches) (A3), at up to 50% less cost-per-page than laser, and handle high-volume printing needs.
  • Print big
    Print up to 27,9 x 43,18 cm (11 x 17 inches) (A3). Scan and copy up to legal size.The HP OfficeJet Pro 7730 comes the same family as the iF Design Award 2017 winner HP OfficeJet Pro 7740.Breeze through tasks with the 35-page automatic document feeder, and get automatic two-sided printing.Take control of print, scan, copy, and fax jobs, using the colour touchscreen and timesaving shortcuts.
  • Present professionally
    Print up to 3x as many black-text and 2x as many colour pages, with optional HP high-yield ink cartridges.Create vibrant colour graphics and black text, ideal for brochures, presentations, and other office documents.Produce water-, smear-, and fade-resistant prints that stand up to highlighters.Create borderless brochures, flyers, photos, and other documents that look great – right in your office.
  • Easy mobile printing with HP Smart app
    Easily print from a variety of smartphones and tablets.Connect your smartphone or tablet directly to your printer – and easily print without accessing a network.Get the power of your printer in the palm of your hand, with the HP Smart app.Simply tap the print button on your smartphone or tablet to print.
  • High-volume printing
    Take on high-volume jobs with confidence, using two 250-sheet paper trays.
HP Officejet Pro 7730 Wide Format All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Recommended Monthly Volume
250 - 1500 pages
Max Copying Speed
Up to 34 ppm (mono) / up to 34 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 dpi
Display
2.65"
Original Size
216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
297 x 431.8 mm (max)
Media Type
Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper
Standard Media Capacity
250 sheets
Output Trays Capacity
75 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Scan to PC
AC 120/230 V (50/60Hz)
58.49 cm x 44.48 cm x 38.58 cm
18.5 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
250 - 1500 pages
Display Diagonal Size
2.65"
Colour Support
Display Features
Touch screen
AirPrint Enabled
Scan to PC
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy, quality adjustment
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1568 nozzles (black), 6272 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
9 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Broadcast Transmission
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
Max Original Size
216 x 356 mm
Original Type
Sheets
35 sheets
Max Media Size
A3
Min Media Weight
60 g/m²
Max Media Weight
105 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm)
250 sheets
75 sheets
ADF - 35 sheets size: 76 x 127 mm - 216 x 356 mm , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets
Speed Details
Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 18 ppm - B/W (ISO) , Printing: up to 22 ppm (A4) - B/W normal , Printing: up to 34 ppm (A4) - colour draft , Copying: up to 13 ppm (A4) - colour (ISO) , Copying: up to 18 ppm (A4) - B/W (ISO) , Copying: up to 34 ppm (A4) - B/W draft , Copying: up to 34 ppm (A4) - colour draft
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x modem - RJ-11
Security Protocols & Features
Apple Bonjour, WEP, WPA, AES
Operating System Support
Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
Software Included
HP Photo Creations, HP Update, Google Toolbar, Software HP Printer
29.4 Watt
Power Consumption Standby
6.02 Watt
Power Consumption Sleep
1.42 Watt
BSMI, GS, CCC, FCC CFR47 Part 68, UL 60950-1 Second Edition, FCC CFR47 Part 15 B, IPv6 Ready, EAC, GB4943.1-2011, IEC 60950-1:2005 Second Edition, EN 61000-3-3:2013, EN 55024:2010, EN 61000-3-2:2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, R&TTE Directive 1999/5/EC, EN 55032:2012, TIA-968-B, ICES-003 issue 6, ICES-003 issue 6 Class B, CISPR 32:2012 Class A, CAN/CSA-C22.2 No. 60950-1-07 Second Edition
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
58.49 cm
44.48 cm
38.58 cm
18.5 kg
Shipping Width
67.7 cm
Shipping Depth
49.5 cm
Shipping Height
48.7 cm
Shipping Weight
23.13 kg
Sound Emission
61 dBA (operating)
5 °C
8 - 85%
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Max Print Speed: 34ppm
Max Paper Size: 297 x 431.8 mm
Brand: HP
Price Range Ex VAT: 100 - 150
