Get professional-quality colour that's ready for business. Easily print up to 27,9 x 43,18 cm (11 x 17 inches) (A3), at up to 50% less cost-per-page than laser, and handle high-volume printing needs.
Print big
Print up to 27,9 x 43,18 cm (11 x 17 inches) (A3). Scan and copy up to legal size.The HP OfficeJet Pro 7730 comes the same family as the iF Design Award 2017 winner HP OfficeJet Pro 7740.Breeze through tasks with the 35-page automatic document feeder, and get automatic two-sided printing.Take control of print, scan, copy, and fax jobs, using the colour touchscreen and timesaving shortcuts. -
Present professionally
Print up to 3x as many black-text and 2x as many colour pages, with optional HP high-yield ink cartridges.Create vibrant colour graphics and black text, ideal for brochures, presentations, and other office documents.Produce water-, smear-, and fade-resistant prints that stand up to highlighters.Create borderless brochures, flyers, photos, and other documents that look great – right in your office. -
Easy mobile printing with HP Smart app
Easily print from a variety of smartphones and tablets.Connect your smartphone or tablet directly to your printer – and easily print without accessing a network.Get the power of your printer in the palm of your hand, with the HP Smart app.Simply tap the print button on your smartphone or tablet to print. -
High-volume printing
Take on high-volume jobs with confidence, using two 250-sheet paper trays.
- HP Officejet Pro 7730 Wide Format All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Recommended Monthly Volume
- 250 - 1500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 13 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 18 ppm 34 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 dpi
- Display
- 2.65"
- Original Size
- 216 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 297 x 431.8 mm (max)
- Media Type
- Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 75 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Scan to PC
- Power
- AC 120/230 V (50/60Hz)
- 58.49 cm x 44.48 cm x 38.58 cm
- 18.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 250 - 1500 pages
- Display Diagonal Size
- 2.65"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Scan to PC
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, quality adjustment
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1568 nozzles (black), 6272 nozzles (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 9 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Broadcast Transmission
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
- Max Original Size
- 216 x 356 mm
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A3
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 105 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm)
- 250 sheets
- 75 sheets
- ADF - 35 sheets size: 76 x 127 mm - 216 x 356 mm , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets
- Speed Details
- Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 18 ppm - B/W (ISO) , Printing: up to 22 ppm (A4) - B/W normal , Printing: up to 34 ppm (A4) - colour draft , Copying: up to 13 ppm (A4) - colour (ISO) , Copying: up to 18 ppm (A4) - B/W (ISO) , Copying: up to 34 ppm (A4) - B/W draft , Copying: up to 34 ppm (A4) - colour draft
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x modem - RJ-11
- Apple Bonjour, WEP, WPA, AES
- Operating System Support
- Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
- Software Included
- HP Photo Creations, HP Update, Google Toolbar, Software HP Printer
- Voltage Required
- 29.4 Watt
- Power Consumption Standby
- 6.02 Watt
- Power Consumption Sleep
- 1.42 Watt
- BSMI, GS, CCC, FCC CFR47 Part 68, UL 60950-1 Second Edition, FCC CFR47 Part 15 B, IPv6 Ready, EAC, GB4943.1-2011, IEC 60950-1:2005 Second Edition, EN 61000-3-3:2013, EN 55024:2010, EN 61000-3-2:2014, R&TTE Directive 1999/5/EC, EN 55032:2012, TIA-968-B, ICES-003 issue 6, ICES-003 issue 6 Class B, CISPR 32:2012 Class A, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- ENERGY STAR Certified
- Limited warranty - 1 year , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
- 58.49 cm
- 44.48 cm
- 38.58 cm
- 18.5 kg
- Shipping Width
- 67.7 cm
- Shipping Depth
- 49.5 cm
- Shipping Height
- 48.7 cm
- Shipping Weight
- 23.13 kg
- Sound Emission
- 61 dBA (operating)
- 5 °C
- 40 °C
- 8 - 85%
