Easily print on a variety of paper sizes up to 29.7 x 42 cm (A3). Produce professional-quality colour for up to 50% less cost per-page than lasers on a printer that's ready for business.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Easy mobile printing
Easily print from your smartphone, tablet, and notebook at work, home, or on the go. -
Wi-Fi Direct
Print wirelessly from your mobile device without a Wi-Fi code or password. -
35-page ADF
Allows multiple pages to be copied or scanned at one time.
- HP Officejet Pro 7720 Wide Format All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 13 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 18 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 dpi
- Display
- 2.65"
- Original Size
- 216 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 297 x 431 mm (max)
- Media Type
- Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 75 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Scan to PC
- Power
- AC 120/230 V (50/60Hz)
- 58.49 cm x 69.06 cm x 30.64 cm
- 15.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 250 - 1500 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Scan to PC
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, quality adjustment
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1568 nozzles (black), 6272 nozzles (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Broadcast Transmission
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
- Max Original Size
- 216 x 356 mm
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A3
- Min Media Weight
- 34 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm)
- 250 sheets
- 75 sheets
- ADF - 35 sheets size: 76 x 127 mm - 216 x 356 mm , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets
- Speed Details
- Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 34 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Copying: up to 34 ppm (A4) - B/W draft , Copying: up to 34 ppm (A4) - colour draft , Copying: up to 34 ppm (Letter A) - B/W draft , Copying: up to 34 ppm (Letter A) - colour draft , Printing: up to 34 ppm (Letter A) - B/W draft , Printing: up to 34 ppm (Letter A) - colour draft
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x modem - RJ-11 , 1 x USB host - 4 pin USB Type A
- Apple Bonjour, WEP, WPA, AES
- Operating System Support
- Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
- Software Included
- HP Photo Creations, HP Update, Google Toolbar, Software HP Printer
- Voltage Required
- IPv6 Ready
- ENERGY STAR Certified
- Limited warranty - 1 year
- 58.49 cm
- 69.06 cm
- 30.64 cm
- 15.5 kg
- Shipping Width
- 67.7 cm
- Shipping Depth
- 49.5 cm
- Shipping Height
- 40.8 cm
- Shipping Weight
- 19.5 kg
- Sound Emission
- 60 dBA (operating)
- 5 °C
- 40 °C
- 10 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.68 |
HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless | In Stock | £4.91 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.41 |
HP Advanced Photo Paper - Glossy photo paper - A3 (297x420mm) | In Stock | £19.94 |
HP 953XL High Yield Black Original Ink cartridge for Officejet | In Stock | £42.17 |
HP 953XL High Yield Cyan Original Ink cartridge for Officejet | In Stock | £29.83 |
HP 953XL High Yield Magenta Original Ink cartridge for Officeje | In Stock | £29.83 |
HP 953XL High Yield Yellow Original Ink cartridge for Officejet | In Stock | £29.83 |
HP 953 CMYK Original INK Cartridge 4 | In Stock | £77.97 |
