HP Officejet Pro 6230 Colour InkJet ePrinter
Print wirelessly from your smartphone, tablet and notebook!
Quicklinx: B0R3WS00 Mfr#: E3E03A#A81
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
More than 50 in stock
£50.08 ex VAT
£60.09 inc VAT
Enjoy professional colour documents and eye-catching marketing materials – for up to 50% less cost per page than lasers. This ePrinter is designed for productivity and mobile printing to keep business moving – at work, home or on the go.
  • Print on your terms
    Print wirelessly from your smartphone, tablet and notebook – no router or access to local network required.Print photos, documents and more when you're on the go – from virtually anywhere – using HP ePrint.Easily connect to your local network and the Internet, wirelessly or using the 10/100 Ethernet port.Boost productivity with the free HP All-in-One Printer Remote mobile app for high-quality mobile scanning.
  • Work smarter and effortlessly
    Reload paper less often and handle large print jobs, using the 225-sheet paper tray.Depend on a printer with an up to 15,000-page monthly duty cycle – the perfect fit for reliable colour printing.Lock in quality. For fast-drying results that resist fading for decades, HP recommends ColorLok paper.
  • Conserve resources without sacrificing performance
    Use up to 50% less energy compared with the majority of colour laser AiOs.Use up to 80% less supplies and packaging by weight compared with lasers.Help reduce energy costs. This ePrinter turns off automatically when it's not needed.Reduce your environmental impact – easily recycle your Original HP ink cartridges for free.
HP Officejet Pro 6230 ePrinter - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
5.1 kg
EMEA (excluding Israel, Saudi Arabia)
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 18 ppm - B/W (ISO/IEC 24734) , Up to 10 ppm - color (ISO/IEC 24734) , Up to 29 ppm - black draft - A4 (210 x 297 mm) , Up to 24 ppm - colour draft - A4 (210 x 297 mm) , Up to 29 ppm - black draft - ANSI A (Letter) (216 x 279 mm) , Up to 24 ppm - colour draft - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
600 x 1200 dpi
Max Resolution (Colour)
600 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
500 MHz
RAM Installed (Max)
128 MB (128 MB) - DDR3 SDRAM
Flash Memory Installed (Max)
128 MB
Language Simulation
PCL 3, PCL 3E
Media Type
Envelopes, plain paper, photo paper, cards, thick paper, glossy paper, matte paper
Total Media Capacity
225 sheets
Monthly Duty Cycle (max)
15000 pages
Recommended Monthly Volume
200 - 800 pages
Print server
Printer Features
Borderless printing
AC 120/230 V
Linux, Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8, Windows 8.1 (32/64 bits), Apple MacOS X 10.9
3-year warranty with product registration
46.4 cm x 38.5 cm x 14.55 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1088 nozzles (black), 672 nozzles (colour)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
600 x 1200 dpi
600 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
14 sec
First Print Out Time Colour
17 sec
Language Simulation
PCL 3, PCL 3E
Colour Management Features
ColorLok Technology
Printer Features
Borderless printing
500 MHz
RAM
RAM Installed (Max)
128 MB / 128 MB (max)
Technology / Form Factor
DDR3 SDRAM
Flash Memory
Flash Memory
128 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
Card / Label Sizes
US 5 x 8 Card (127.0 x 203.2 mm), Hagaki Card (100 x 148 mm), 76.2 x 127 mm, 101.6 x 152.4 mm
Media Weight
60 g/m² - 280 g/m²
225 sheets
Media Feeders
1 x automatic - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m²
Max Media Capacity
225 sheets
Output Trays Capacity
60 sheets
Duty Cycle
15000 pages
200 - 800 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
FCC Class B certified, BSMI, CISPR 22 Class B, EN55022 Class B, EMC, FCC CFR47 Part 15, KCC, LVD, KC, VCCI V-2, EN 62311, EN 61000-3-2:2006+A1:2009+A2:2009, ICES-003 issue 5 Class B, EN55024:2010, EN61000-3-3:2008, RCM, IEC 62311, IEC 60950-1:2005 Second Edition, EN 60950-1:2006+ A11
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
24 Watt
Power Consumption Sleep
1.16 Watt
System Requirements Details
Windows Vista/7/8/8.1 - HD 2 GB , Windows Vista - 800 MHz HD 2 TB , Windows XP - Pentium II - 233 MHz HD 750 MB
Environmental Standards
ENERGY STAR
Limited warranty - 3 years with product registration (within 60 days of purchase)
5 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
63 dBA
46.4 cm
38.5 cm
14.55 cm
5.1 kg
Width (Shipping)
50.8 cm
Depth (Shipping)
19.4 cm
Height (Shipping)
44.9 cm
Weight (Shipping)
7 kg
HP Officejet Pro 6230 Colour InkJet ePrinter Bundle deal on HP Officejet Pro 6230 Colour InkJet ePrinter
Bundle includes:
HP 935XL Officejet Value Pack Cyan, Magenta & Yellow Inks HP 935XL Officejet Value Pack Cyan, Magenta & Yellow Inks worth £36.20 | in stock
£86.28
Ink (1)
B0R3 HP Professional Glossy Inkjet Paper-50 sheet/A4/210 x 297 mm In Stock £9.43
Other bundles (7)
B0R3 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.90
B0R3 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.05
B0R3 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.83
B0R3 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.66
B0R3 C2G USB Superbooster Extender Kit In Stock £37.61
B0R3 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.49
B0R3 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: 50 - 100
