A printing revolution for your enterprise. HP Officejet MFPs deliver colour prints at up to twice the speed and half the cost per page of colour lasers – plus copy, scan and fax[1,2,3]. They're designed for advanced workflow – and built to last.
Twice the speed and half the cost of lasers
Quality colour, up to half the cost. Spend up to 50% less per page compared with colour lasers.Accelerate business printing and keep productivity high – print up to twice as fast as lasers.Rely on pigment inks for durable documents that are water-, fade- and smear-resistant.Designed for speed – enable full-page-width printing at high speeds with HP PageWide Technology. -
A fully loaded printer for the enterprise
Be confident that sensitive business data is protected with advanced security solutions.Centrally monitor and control your printers with HP Web Jetadmin.Deploy new features through upgradable firmware and add solutions to expand the capabilities of this MFP.Enable optional wireless direct printing and NFC touch-to-print technology – no need to access the network,. -
Performance you can rely on
High volume, high value – get exceptional value from Original HP high-capacity black ink cartridges.Up to the task – choose a robust MFP designed for demanding, high-volume workloads.Rely on longevity – this MFP is designed for less maintenance, with minimal consumable parts.Loaded for productivity – tackle large print jobs with a paper capacity of up to 1,050 sheets. -
Make workflow faster
Worry-free scanning – capture every page and detect potential misfeeds before they slow you down.Finish faster – scan in a single pass and send documents to network folders, email and more.Manage jobs directly at the MFP, using the 20.3 cm (8 inch) colour touchscreen with image preview.Fast, accurate input – enter data more quickly and accurately using the pull-out keyboard.
- HP Officejet Enterprise Color MFP X585dn - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP PageWide
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 2000 - 6000 pages
- Max Copying Speed
- Up to 44 ppm (mono) / up to 44 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 42 ppm (mono) / up to 42 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, soft gloss photo paper
- Standard Media Capacity
- 550 sheets
- Max Media Capacity
- 1050 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host, USB host (internal)
- AirPrint Enabled
- Office Machine Features
- Document send function, save to USB flash drive, scan to e-mail, Hardware Integration Pocket, save to network folder, Foreign Interface Harness (FIH)
- Power
- AC 120/230 V (50/60Hz)
- 53.3 cm x 54.6 cm x 57.4 cm
- 36.3 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified, Blue Angel
- Ink-jet - colour
- 75000 pages
- 2000 - 6000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.75 GB
- Max Supported Memory
- 1.75 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
Printing
- Inkjet Technology
- HP PageWide
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.4
- First Print Out Time B/W
- 8 sec
- First Print Out Time Colour
- 8 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), 102 x 210 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
- 550 sheets
- 1050 sheets
- 50 sheets
- 300 sheets
- Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Input tray - 500 sheets size: 102 x 210 mm - 216 x 297 mm weight: 60 g/m² - 250 g/m² , Output tray - 300 sheets , ADF - 50 sheets - Legal (216 x 356 mm)
- Speed Details
- Printing: up to 70 ppm (A4) - B/W draft , Printing: up to 70 ppm (A4) - colour draft , Printing: up to 42 ppm (A4) - B/W (ISO) , Printing: up to 42 ppm (A4) - colour (ISO) , Copying: up to 44 ppm - B/W (ISO) , Copying: up to 44 ppm - colour (ISO) , Printing: up to 44 ppm (Letter A) - B/W (ISO) , Scanning: up to 41 ipm (A4) - B/W normal , Scanning: up to 41 ipm (A4) - colour normal , Scanning: up to 16 ipm (A4) - B/W duplex , Printing: up to 72 ppm (Letter A) - B/W draft , Printing: up to 72 ppm (Letter A) - colour draft , Scanning: up to 44 ipm (Letter A) - B/W normal , Scanning: up to 44 ipm (Letter A) - colour normal , Printing: up to 44 ppm (Letter A) - colour (ISO) , Printing: up to 38 ipm (A4) - B/W duplex , Printing: up to 38 ipm (A4) - colour duplex , Scanning: up to 16 ipm (A4) - colour duplex , Scanning: up to 17 ppm (Letter A) - B/W duplex , Scanning: up to 17 ppm (Letter A) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 2 x USB host (internal) - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x
- Operating System Support
- HP-UX 11.x, SunSoft Solaris 2.5 or later, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), HP-UX 11i, Novell NetWare 5.1, Apple Mac OS X 10.6, Red Hat Linux 7.x or later, SUSE Linux 8.x or later, IBM AIX 3.2.5 or later, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, HP-UX 10.20, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2003 x64 Edition SP2 or later, Windows 8.1, MS Windows Server 2008 (32/64-bits)
- Software Included
- Drivers & Utilities, HP Web Jetadmin
- Voltage Required
- 67 Watt
- Power Consumption Standby
- 34 Watt
- Power Consumption Sleep
- 9 Watt
- Consumables Included
- 1 x ink cartridge (pigmented black) - up to 7800 pages , 1 x ink cartridge (pigmented yellow) - up to 3400 pages , 1 x ink cartridge (pigmented cyan) - up to 3400 pages , 1 x ink cartridge (pigmented magenta) - up to 3400 pages
- FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EN55022 Class A, EMC, FCC CFR47 Part 15, IEC 60950-1, LVD, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 62479, EN 62479:2010, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Blue Angel Compliant
- 53.3 cm
- 54.6 cm
- 57.4 cm
- 36.3 kg
- Shipping Width
- 70.9 cm
- Shipping Depth
- 63.8 cm
- Shipping Height
- 74.2 cm
- Shipping Weight
- 45 kg
- Sound Emission
- 53 dBA (operating)
- 15 °C
- 30 °C
- 20 - 80%
