Your basket is empty
HP Officejet Enterprise X585dn Colour Multifunction Printer
Trade in your old printer!
Limited Time Offer
Quicklinx: 9G9BWS00 Mfr#: B5L04A#B19
A printing revolution for your enterprise. HP Officejet MFPs deliver colour prints at up to twice the speed and half the cost per page of colour lasers – plus copy, scan and fax[1,2,3]. They're designed for advanced workflow – and built to last.
HP Officejet Enterprise Color X585dn - multifunction printer (colour)
Printer / copier / scanner
English, German, French, Italian, Spanish / Europe
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP PageWide
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
2000 - 6000 pages
Max Copying Speed
Up to 44 ppm (mono) / up to 44 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 70 ppm (mono) / up to 70 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
8"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, soft gloss photo paper
Standard Media Capacity
550 sheets
Max Media Capacity
1050 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host, USB host (internal)
AirPrint Enabled
Office Machine Features
Document send function, save to USB flash drive, scan to e-mail, HP ePrint, Hardware Integration Pocket, save to network folder, Foreign Interface Harness (FIH)
AC 120/230 V (50/60Hz)
53.3 cm x 54.6 cm x 57.4 cm
36.3 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel, EPEAT Silver
Printing Technology
Ink-jet - colour
75000 pages
2000 - 6000 pages
Display Diagonal Size
8"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
1792 MB
Max Supported Memory
1792 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Inkjet Technology
HP PageWide
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.4
Automatic Duplexing
First Print Out Time B/W
8 sec
First Print Out Time Colour
8 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), 102 x 210 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
550 sheets
Max Media Capacity
1050 sheets
50 sheets
300 sheets
Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Input tray - 500 sheets size: 102 x 210 mm - 216 x 297 mm weight: 60 g/m² - 250 g/m² , Output tray - 300 sheets , ADF - 50 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 70 ppm (A4) - B/W draft , Printing: up to 70 ppm (A4) - colour draft , Printing: up to 42 ppm (A4) - B/W (ISO) , Printing: up to 42 ppm (A4) - colour (ISO) , Copying: up to 44 ppm - B/W (ISO) , Copying: up to 44 ppm - colour (ISO) , Printing: up to 44 ppm (Letter A) - B/W (ISO) , Scanning: up to 41 ipm (A4) - B/W normal , Scanning: up to 41 ipm (A4) - colour normal , Scanning: up to 16 ipm (A4) - B/W duplex , Printing: up to 72 ppm (Letter A) - B/W draft , Printing: up to 72 ppm (Letter A) - colour draft , Scanning: up to 44 ipm (Letter A) - B/W normal , Scanning: up to 44 ipm (Letter A) - colour normal , Printing: up to 44 ppm (Letter A) - colour (ISO) , Printing: up to 38 ipm (A4) - B/W duplex , Printing: up to 38 ipm (A4) - colour duplex , Scanning: up to 16 ipm (A4) - colour duplex , Scanning: up to 17 ppm (Letter A) - B/W duplex , Scanning: up to 17 ppm (Letter A) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 2 x USB host (internal) - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x
Operating System Support
HP-UX 11.x, SunSoft Solaris 2.5 or later, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), HP-UX 11i, Novell NetWare 5.1, Apple Mac OS X 10.6, Red Hat Linux 7.x or later, SUSE Linux 8.x or later, IBM AIX 3.2.5 or later, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, HP-UX 10.20, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2003 x64 Edition SP2 or later, Windows 8.1, MS Windows Server 2008 (32/64-bits)
Software Included
Drivers & Utilities, HP Web Jetadmin
67 Watt
Power Consumption Standby
34 Watt
Power Consumption Sleep
9 Watt
Consumables Included
1 x Cartridge (pigmented black) - up to 7800 pages , 1 x Cartridge (pigmented yellow) - up to 3400 pages , 1 x Cartridge (pigmented cyan) - up to 3400 pages , 1 x Cartridge (pigmented magenta) - up to 3400 pages
FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EN55022 Class A, EMC, FCC CFR47 Part 15, IEC 60950-1, LVD, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 62479, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 62479:2010, EN55024:2010
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Blue Angel Compliant
53.3 cm
54.6 cm
57.4 cm
36.3 kg
Shipping Width
70.9 cm
Shipping Depth
63.8 cm
Shipping Height
74.2 cm
Shipping Weight
45 kg
Sound Emission
53 dBA (operating)
15 °C
30 °C
20 - 80%
