Brand
HP Officejet 8012e A4 All-in-One Inkjet Printer with 6 month of instant ink with HP plus
Quicklinx: GG03WS00 Mfr#: 228F8B#687
11 in stock
£99.99 ex VAT
£119.98 inc VAT
Count on fast print speeds up to 20 ppm, automatic two-sided printing, easy mobile printing, and reliable Wi-Fi connectivity. Choose HP+ at setup to receive 6 months of Instant Ink and an extended (up to 3 years) HP warranty.
This printer is best for shared home offices doing a range of print tasks, including professional colour documents and even a few photos.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer.
  • Customisable shortcuts on your phone
    Eliminate steps in repetitive tasks with Shortcuts in HP Smart app.
  • Hands-free. Auto-fed
    Work fast and hands-free with the 35 page auto-feeder.
  • Ready when you are
    Connect to cloud-based printing with Wi-Fi or your cellular network.
  • Printing just got more productive
    Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
  • Your reliable connection
    Reduce interruptions with self-healing Wi-Fi that keeps you connected.
HP Officejet 8012e All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
800 pages
Max Copying Speed
Up to 13 ppm (mono) / up to 7 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 18 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Display
2.2"
Original Size
127 x 127 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, recycled paper, photo paper, light-weight paper, glossy paper, matte paper
Standard Media Capacity
225 sheets
Max Media Capacity
225 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
Wi-Fi(n)
AirPrint Enabled
Office Machine Features
HP Auto Wireless Connect, scan to PC, HP Instant Ink, print from mobile devices, scan to PDF
AC 120/230 V (50/60Hz)
46 cm x 34.12 cm x 23.4 cm
8.2 kg
1-year warranty
Printing Technology
Ink-jet - colour
20000 pages
800 pages
Display Diagonal Size
2.2"
Display Features
Touch screen
Wi-Fi(n)
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
Collation copy, margin shift, quality adjustment, preview, resize, ID Copy
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1760 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
13 sec
First Print Out Time Colour
17 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
127 x 127 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
Borderless Photo Sizes
225 sheets
Max Media Capacity
225 sheets
60 sheets
ADF - 35 sheets size: 127 x 127 mm - Legal (216 x 356 mm) , Input tray - 225 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m²; weight (lbs): 16 lbs - 110 lbs , Output tray - 60 sheets
Speed Details
Printing: up to 28 ppm (A4) - B/W draft , Printing: up to 24 ppm (A4) - colour draft , Printing: up to 28 ppm (Letter A) - B/W draft , Printing: up to 24 ppm (Letter A) - colour draft , Printing: up to 18 ppm (A4) - B/W (ISO) , Printing: up to 18 ppm (Letter A) - B/W (ISO) , Printing: up to 10 ppm - colour (ISO) , Printing: up to 3 ppm (A4) - B/W best , Printing: up to 3 ppm (Letter A) - B/W best , Copying: up to 28 ppm (A4) - B/W draft , Copying: up to 22 ppm (A4) - colour draft , Copying: up to 28 ppm (Letter A) - B/W draft , Copying: up to 22 ppm (Letter A) - colour draft , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 7 ppm , Copying: up to 3 ppm (A4) - B/W best , Copying: up to 2 ppm (A4) - colour best , Copying: up to 3 ppm (Letter A) - B/W best , Copying: up to 2 ppm (Letter A) - colour best , Scanning: up to 8 ppm (A4) - B/W normal , Scanning: up to 3.5 ppm (A4) - colour normal , Scanning: up to 8 ppm (Letter A) - B/W normal , Scanning: up to 3.5 ppm (Letter A) - colour normal
Security Protocols & Features
Wi-Fi Direct
Software Included
HP Smart App
21 Watt
Power Consumption Standby
5.8 Watt
Power Consumption Sleep
0.9 Watt
Setup poster
Consumables Included
1 x Cartridge (black) - up to 255 pages - HP 912 , 1 x Cartridge (cyan) - HP 912 , 1 x Cartridge (magenta) - HP 912 , 1 x Cartridge (yellow) - HP 912
GS, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, TLS, EN 61000-3-2:2014, UL 62368-1 Second Edition, CISPR 32:2012, EN 301 489-17 V3.1.1 (2017), SSL, EN 55032:2012 Class B, EN 301 489-1 V2.1.1:2017, RU EAC, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, ES 203 021-2, ES 203 021-3, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, IEC60950-1:2005, Second edition + Am1:2009 + A2:2013, EN 62368-1:2014/A11:2017
Limited warranty - 1 year
46 cm
34.12 cm
23.4 cm
8.2 kg
Shipping Width
50.6 cm
Shipping Depth
29.8 cm
Shipping Height
40.8 cm
Shipping Weight
10.4 kg
Sound Emission
61 dBA (operating)
5 °C
20 - 80%
Ink (3)
GG03 HP 912 Black Original Ink Cartridge In Stock £10.62
GG03 HP 912 Cyan Original Ink Cartridge In Stock £4.18
GG03 HP 912XL High Yield Cyan Original Ink Cartridge In Stock £12.21
Other bundles (1)
GG03 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £27.21
Type: Printer / copier / scanner
Functionality: Copier
Functionality: Scanner
Functionality: Printer
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Stock Status: In stock
