HP Officejet 7510 Wide Format Colour InkJet Multifunction Printer
Quicklinx: BDWHWS00 Mfr#: G3J47A#A80
Help your business stand out with stunning, wide-format colour prints at a price that you can afford. Accelerate productivity and keep business moving with a wide range of tools. Create professional-quality marketing materials – right in the office.
  • Get whatever you need – as fast as you need it
    Scan, copy and fax from one device and print in a wide range of sizes – for virtually any business need.Easily access, print and share resources on a network with built-in Ethernet and wireless capabilities.Scan to your USB drive, PC and email, and fax to your PC for quick and easy access.Walk up and print or scan right from a memory device via the easy-access USB port.
  • Enjoy affordable, professional-quality printing
    Help your business save with low-cost printing – from photos to borderless marketing materials.Ensure you never throw away useable ink, with Original HP individual ink cartridges.Count on laser-quality black text and stunning colour graphics and photos – right in the office.Create professional-quality borderless flyers, brochures and more – directly from your wide-format all-in-one.
  • Get more done in less time
    Access time-saving, built-in business apps – just tap and swipe the 6.73 cm (2.65-inch) touchscreen.Easily print from your mobile device and stay connected on the go – even without accessing a network.Manage printing tasks and scan on the go with the free HP All-in-One Printer Remote mobile app.Easily scan identification cards and other two-sided documents onto a single page.
  • Save energy
    Schedule your printer to turn on when you need it and off when you don't – and save up to 40% on energy use.Conserve resources, using digital fax capabilities that enable you to view and store faxes electronically.
HP Officejet 7510 Wide Format All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
12000 pages
Recommended Monthly Volume
200 - 800 pages
Max Copying Speed
Up to 9 ppm (mono) / up to 6 ppm (colour)
Max Copying Resolution
Up to 600 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Printing Speed
Up to 15 ppm (mono) / up to 8 ppm (colour)
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi
Scanning
1200 dpi
Display
2.65"
Original Size
127 x 178 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
A3 (297 x 420 mm) (max)
Media Type
Plain paper, photo paper, thick paper, glossy paper, matte paper
Standard Media Capacity
250 sheets
Output Trays Capacity
75 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, automatic paper sensor
AC 120/230 V (50/60Hz)
61.3 cm x 48.3 cm x 36.6 cm
13.02 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
12000 pages
200 - 800 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Scanning
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
48 stations
Colour faxing
Document & Media Handling
Min Original Size
127 x 178 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Weight
34 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 130 x 180 mm, 90 x 130 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm)
Supported Envelope Sizes
US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
Borderless Photo Sizes
A3 Plus (305 x 457 mm)
250 sheets
75 sheets
ADF - 35 sheets size: 127 x 178 mm - Legal (216 x 356 mm) , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 34 g/m² - 250 g/m² , Output tray - 75 sheets
Speed Details
Printing: up to 15 ppm - B/W (ISO) , Printing: up to 8 ppm - colour (ISO) , Copying: up to 33 ppm (A4) - B/W draft , Copying: up to 29 ppm (A4) - colour draft , Printing: up to 33 ppm (A4) - B/W draft , Printing: up to 29 ppm (A4) - colour draft , Copying: up to 9 ppm - B/W (ISO) , Copying: up to 6 ppm - colour (ISO) , Printing: up to 33 ppm (Letter A) - B/W draft , Printing: up to 29 ppm (Letter A) - colour draft
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x modem - RJ-11
Operating System Support
Linux, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
Software Included
Drivers & Utilities, HP Photo Creations
27.7 Watt
Power Consumption Standby
4.57 Watt
Power Consumption Sleep
1.89 Watt
EN 61000-3-2:2006, EN 61000-3-3:2008, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
ENERGY STAR Certified
61.3 cm
48.3 cm
36.6 cm
13.02 kg
Shipping Weight
16.55 kg
Sound Emission
57 dBA (operating)
5 °C
20 - 80%
Ink (2)
BDWH HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.68
BDWH HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.69
Other bundles (1)
BDWH C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
