Do more in-house with this affordable, reliable HP ePrinter. Create professional-quality marketing materials from postcard size to A3+. Share the performance with wireless networking and the ability to print from virtually anywhere.
Create professional-quality materials with affordable wide-format printing
Do more in-house – print high-impact marketing materials from postcard to A3+ with this wide format printer.Print professional-quality colour for up to 50% lower cost per page than lasers.Produce borderless brochures, flyers, brochures and more for less than a print shop.Print affordably with four individual inks – only replace the ones you need. -
Maximise productivity – handle large print jobs with this compact printer
Stay productive – load up the 250-sheet paper tray and leave long print jobs to themselves.Minimise intervention – optional high capacity XL ink cartridges available for frequent printing.Keep your printer close to your desk or neatly out of the way – compact design fits where you need it.Enjoy worry-free performance from a printer designed for volumes of up to 800 pages per month. -
Connect, print and stay productive – at the office or on the go
Add this high performance printer to your wireless network and share with other wireless-enabled PCs.Enjoy the flexibility of being able to print from smartphones or tablets from virtually anywhere with HP ePrint.Share the performance across small workgroups by adding this versatile printer to your Ethernet network.Give your smartphone a print button – use the free HP ePrint app to print directly from your mobile device. -
Conserve resources without sacrificing performance
Save energy without sacrificing performance – this device is ENERGY STAR qualified and rated EPEAT Bronze.Save up to 50% on paper costs with optional automatic two-sided printing.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
- HP Officejet 7110 Wide Format ePrinter - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 8.5 kg
- Localisation
- English / United Kingdom
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A3
- Max Media Size
- Super A3/B (330 x 483 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 330 mm x 483 mm
- Print Speed
- Up to 33 ppm - black draft - A4 (210 x 297 mm) , Up to 29 ppm - colour draft - A4 (210 x 297 mm) , Up to 15 ppm - black laser quality , Up to 8 ppm - colour laser quality
- Max Resolution (B&W)
- 600 x 1200 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Automatic Duplexing
- Optional
- Interface
- USB, LAN, Wi-Fi(n)
- AirPrint Enabled
- Processor
- 500 MHz
- RAM Installed (Max)
- 128 MB (128 MB) - DDR SDRAM
- Language Simulation
- PCL 3, PCL 3E
- Media Type
- Envelopes, labels, plain paper, photo paper, index cards, cards
- Total Media Capacity
- 250 sheets
- Monthly Duty Cycle (max)
- 12000 pages
- Recommended Monthly Volume
- 200 - 800 pages
- Networking
- Print server
- Printer Features
- Borderless printing
- Power
- AC 120/230 V
- System Requirements
- Linux, Apple MacOS X 10.6, Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Windows 8 (32/64 bits), Apple MacOS X 10.8
- 3-year warranty with product registration
- 58.5 cm x 41.9 cm x 18.9 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 600 x 1200 dpi
- 4800 x 1200 dpi
- Optional
- First Print Out Time Colour
- 19 sec
- PCL 3, PCL 3E
- Printer Features
- Processor
- 500 MHz
RAM
- 128 MB / 128 MB (max)
- Technology / Form Factor
- DDR SDRAM
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- 76.2 mm x 127 mm
- 330 mm x 483 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), Super A3/B (330 x 483 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 76.2 x 127 mm
- Borderless Photo Sizes
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
- Media Weight
- 60 g/m² - 300 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Super A3/B (330 x 483 mm) weight: 60 g/m² - 250 g/m²
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 75 sheets
Duty Cycle
- 12000 pages
- 200 - 800 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) - up to 400 pages - HP 932 , 1 x ink cartridge (cyan) - up to 330 pages - HP 933 , 1 x ink cartridge (magenta) - up to 330 pages - HP 933 , 1 x ink cartridge (yellow) - up to 330 pages - HP 933
- EN 60950, GS, NEMKO, IEC 60950, LVD
- Power Device
- Power adapter - external
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 30.3 Watt
- Power Consumption Stand by
- 1.92 Watt
- Power Consumption Sleep
- 1.04 Watt
- Software Included
- Drivers & Utilities, HP Photo Creations
- OS Required
- System Requirements Details
- Windows 7 - 1 GHz HD 2 GB , Windows Vista - 800 MHz HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 750 MB , MacOS X 10.6/10.7/10.8 - Intel Core HD 1 GB , Windows 8 (32/64 bits) - 1 GHz HD 2 GB
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years with product registration (within 60 days of purchase)
- 5 °C
- 40 °C
- 5 - 90% (non-condensing)
- Sound Emission (Operating)
- 51 dBA
- 58.5 cm
- 41.9 cm
- 18.9 cm
- 8.5 kg
- Width (Shipping)
- 68.7 cm
- Depth (Shipping)
- 50 cm
- Height (Shipping)
- 27 cm
- Weight (Shipping)
- 12.7 kg
Ink (1)
Other bundles (4)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.98 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.90 |
C2G 5m USB 2.0 A Male to A Female Active Extension Cable | In Stock | £12.13 |
C2G USB Superbooster Extender Kit | In Stock | £35.89 |
