Remarkable value for professional, in-office colour
• Manage your budget with professional-quality colour at up to 50% less cost per page than lasers.
• Print up to 5x as many black text pages with optional Original HP high-yield ink cartridges.
• Produce professional-quality colour and black text that’s perfect for printing reports, charts, and more.
• Rely on Original HP pigment inks for durable prints that resist water and last for decades.
Easy mobile printing, seamless mobile setup
• Easily print from a variety of smartphones and tablets.
• Connect a smartphone or tablet directly to the printer and easily print without a network.
• Print wirelessly, and share this all-in-one with other wireless-enabled devices.
• Easily manage printing tasks and scan on the go, with the HP All-in-One Printer Remote mobile app.
Handle more tasks without slowing down
• Set the pace for success with rapid print, scan, and copy speeds.
• Save paper and conserve resources—consume up to 50% less paper with automatic two-sided printing.
• Quickly copy, scan, and fax multipage documents with the 35-page automatic document feeder.
• Tap and swipe the touchscreen the same way you would in a smartphone and get instant access to essential tasks.
Colour touchscreen
Manage jobs directly at the MFP, using the HP colour touchscreen. -
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%. -
Automatic document feeder
Allows multiple pages to be copied or scanned at one time. -
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
Scan to email
Save time by sending scanned documents or photos directly from your printer to email recipients. -
HP Mobile Printing
Easily print from your smartphone, tablet, and notebook at work, home, or on the go.
- HP Officejet Pro 6960 All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English / United Kingdom
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 200 - 800 pages
- Max Copying Speed
- Up to 13 ppm (mono) / up to 7 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 18 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 dpi
- Display
- 2.65"
- Original Size
- 212 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, thick paper, glossy paper, matte paper
- Standard Media Capacity
- 225 sheets
- Output Trays Capacity
- 60 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to folder
- Power
- AC 110/230 V (50/60Hz)
- 46.37 cm x 39 cm x 22.867 cm
- 8.05 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 20000 pages
- 200 - 800 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Scan to folder
- Localisation
- Standard Memory
- 1 GB
- Max Supported Memory
- 1 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3e, PCL 3 GUI
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 15 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Broadcast Transmission
- 20 stations
- Delayed Transmission
- Fax forwarding, automatic redialing, auto reduction
Document & Media Handling
- Max Original Size
- 212 x 356 mm
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 88.9 x 127 mm, 101.6 x 127 mm, 76.2 x 127 mm, 152.4 x 203.2 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Borderless Photo Sizes
- 216 x 297 mm
- 225 sheets
- 60 sheets
- Input tray - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , ADF - 35 sheets - 212 x 356 mm , Output tray - 60 sheets
- Speed Details
- Scanning: up to 8 ppm - B/W , Scanning: up to 3.5 ppm - colour , Printing: up to 30 ppm (A4) - B/W draft , Printing: up to 26 ppm (A4) - colour draft , Printing: up to 18 ppm - B/W (ISO) , Printing: up to 10 ppm - colour (ISO) , Copying: up to 30 ppm (A4) - B/W draft , Copying: up to 24 ppm (A4) - colour draft , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO) , Printing: up to 30 ppm (Letter A) - B/W draft , Printing: up to 26 ppm (Letter A) - colour draft
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x modem - RJ-11
- Operating System Support
- Linux, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, MS Windows Server 2008 SP1, MS Windows Server 2003 SP1, MS Windows Server 2003 SP2, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
- Software Included
- Drivers & Utilities
- Voltage Required
- 27 Watt
- Power Consumption Standby
- 5.5 Watt
- Power Consumption Sleep
- 1.21 Watt
- Included Accessories
- Phone cable
- ENERGY STAR Certified
- Limited warranty - 1 year
- 46.37 cm
- 39 cm
- 22.867 cm
- 8.05 kg
- Shipping Width
- 50.8 cm
- Shipping Depth
- 28.2 cm
- Shipping Height
- 46.4 cm
- Shipping Weight
- 10 kg
- Sound Emission
- 61 dBA (operating)
- 15 °C
- 32 °C
- 20 - 80% (non-condensing)
