Produce affordable, professional-quality colour that helps you stand out. Keep work moving with mobile printing and seamless mobile setup. Impressive speeds help you handle projects without slowing down. Save up to 70% on ink with HP Instant Ink.
Produce affordable, professional-quality colour that helps you stand out and save up to 70% on ink with HP Instant Ink.
Great value for professional home office colour
Get affordable, professional-quality colour and rich black text output – ideal for a variety of home office projects. Optional high-yield cartridges offer a better value for frequent printing. Rely on Original HP inks for documents that last.
Easy mobile printing, seamless mobile setup
Easily print when and where you need to from your smartphone, tablet, or notebook PC. Get up and running right out of the box, and connect the way you want to with wireless networking.
Seamless performance without slowing down
Take projects from start to finish with fast, easy all-in-one performance. Save paper with automatic two-sided printing, and speed through jobs with a 35-page automatic document feeder. Handle tasks directly at the 5.6 cm (2.2-inch) touchscreen.
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%.
Automatic document feeder
Allows multiple pages to be copied or scanned at one time
HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint.
Scan to email
Save time by sending scanned documents or photos directly from your printer to email recipients.
Easy mobile printing from HP
Easily print from your smartphone, tablet, and notebook at work, home, or on the go.
HP Instant Ink
Save up to 70% on ink. Original HP ink delivered to your door with HP Instant Ink.
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty. -
Print up to 2.5x as many pages with optional Original HP high-yield ink cartridges.Produce professional-quality colour and black text that's perfect for printing reports, charts, and more.Rely on Original HP pigment inks for durable prints that resist water and last for decades.Print affordably with individual ink cartridges. Simply replace each cartridge separately, as needed. -
Easily print from a variety of smartphones and tablets.Connect a smartphone or tablet directly to the printer, and easily print without a network.Print wirelessly and share this all-in-one with other wireless-enabled devices.Easily manage printing tasks and scan on the go with the HP All-in-One Printer Remote mobile app. -
Set the pace for success with fast print, scan, and copy speeds.Save paper and conserve resources – consume up to 50% less paper with automatic two-sided printing.Quickly copy, scan, and fax multipage documents with the 35-page automatic document feeder.Take charge of printing tasks with the easy-to-5.6 cm (2.2-inch) touchscreen.
- HP Officejet 6950 All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English / United Kingdom
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 200 - 800 pages
- Max Copying Speed
- Up to 28 ppm (mono) / up to 22 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 29 ppm (mono) / up to 24 ppm (colour)
- Max Printing Resolution
- Up to 600 x 1200 dpi (mono) / up to 1200 x 4800 dpi (colour)
- Fax Resolutions
- 203 x 98 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.2"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, photo paper, thick paper, glossy paper, matte paper
- Standard Media Capacity
- 225 sheets
- Max Media Capacity
- 225 sheets
- Output Trays Capacity
- 60 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, HP Auto Wireless Connect
- Power
- AC 120/230 V (50/60Hz)
- 46.37 cm x 51.8 cm x 22.867 cm
- 7.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- 15000 pages
- 200 - 800 pages
- Display Diagonal Size
- 2.2"
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
- Standard Memory
- 1 GB
- Max Supported Memory
- 1 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3e, PCL 3 GUI
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 15 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Telephone / Fax Switch
- Broadcast Transmission
- 20 stations
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 330.2 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Borderless Photo Sizes
- 225 sheets
- 225 sheets
- 60 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 225 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
- Speed Details
- Printing: up to 29 ppm (A4) - B/W draft , Printing: up to 24 ppm (A4) - colour draft , Printing: up to 16 ppm - B/W (ISO) , Printing: up to 9 ppm - B/W (ISO) , Printing: up to 8 ipm (A4) - B/W duplex , Printing: up to 5 ipm - colour duplex , Copying: up to 28 ppm (Letter A) - B/W draft , Copying: up to 22 ppm (Letter A) - colour draft , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO) , Scanning: up to 8 ppm - B/W , Scanning: up to 3.5 ppm - colour , Scanning: up to 4 ppm - B/W duplex , Scanning: up to 1.5 ppm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x modem - RJ-11
- Operating System Support
- Linux, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012, MS Windows Server 2003 SP1, MS Windows Server 2003 SP2, MS Windows Server 2003 x64 Edition SP2 or later, MS Windows Server 2003 x64 Edition SP1 or later, Apple Mac OS X 10.9, MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 SP1 (32/64-bits), MS Windows Server 2008 SP2 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits)
- Voltage Required
- 27 Watt
- Power Consumption Sleep
- 1.21 Watt
- Included Accessories
- USB cable, phone cable, Ethernet cable
- Consumables Included
- 1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
- ENERGY STAR Certified
- 46.37 cm
- 51.8 cm
- 22.867 cm
- 7.7 kg
- Sound Emission
- 61 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
HP Professional Matt Inkjet Paper-100 sht/A3/297 x 420 mm | In Stock | £15.91 |
HP Professional Glossy Inkjet Paper-50 sheet/A4/210 x 297 mm | In Stock | £9.53 |
