Get more done with the easiest way to print from your smartphone or tablet. Simplify tasks while saving time and money with this affordable, easy-to-use all-in-one with fax. It fits in nearly any space and works quietly in the background.
Get easy mobile printing
Start printing and get connected quickly with easy setup from your smartphone, tablet or PC.Connect your smartphone or tablet directly to your printer – and easily print without accessing a network.Manage printing tasks and scan on the go with the free HP All-in-One Printer Remote mobile app.Easily print from a variety of smartphones and tablets. Your pages come out great – even if you're not there. -
Get everything you need – right away
Take charge of your tasks and finish in less time with the easy-to-use 5.5 cm (2.2-inch) display.Quickly copy, scan and fax multipage documents with the 35-page automatic document feeder.No need to wait – start printing right away with easy setup. Automatically connect to your wireless network. -
Count on a product designed to fit your life
Save your space with a compact all-in-one designed to fit on your desk, on a shelf or anywhere you need it.Print in any room you choose – without causing disruptions. Optional quiet mode helps keep noise to a minimum.
- HP Officejet 3830 All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English / United Kingdom, Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 100 - 250 pages
- Max Copying Speed
- Up to 7 ppm (mono) / up to 3.5 ppm (colour)
- Max Copying Resolution
- Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
- Max Printing Speed
- Up to 8.5 ppm (mono) / up to 6 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.2"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 215 x 355 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
- Standard Media Capacity
- 60 sheets
- Output Trays Capacity
- 25 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Power
- AC 120/230 V (50/60Hz)
- 45 cm x 36.4 cm x 22.44 cm
- 5.61 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 1000 pages
- 100 - 250 pages
- Display Diagonal Size
- 2.2"
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Maximum Copies
- 20
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI, PCLm
- First Print Out Time B/W
- 14 sec
- First Print Out Time Colour
- 17 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- PC Faxing
Fax Machine Features
- Speed Dialing
- 50 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, Distinctive Ring Detection (DRD)
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm)
- 60 sheets
- 25 sheets
- Input tray - 60 sheets - 215 x 355 mm weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
- Speed Details
- Printing: up to 8.5 ppm - B/W (ISO) , Printing: up to 6 ppm - colour (ISO) , Copying: up to 7 ppm - B/W (ISO) , Copying: up to 3.5 ppm - colour (ISO) , Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 16 ppm (Letter A) - colour draft
- 1 x USB 2.0 - 4 pin USB Type B , 1 x modem - RJ-11
- Operating System Support
- MS Windows XP SP3, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
- Software Included
- Drivers & Utilities, HP Photo Creations
- Voltage Required
- 10 Watt
- Power Consumption Standby
- 2.83 Watt
- Power Consumption Sleep
- 1.17 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302
- GOST, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
- ENERGY STAR Certified
- Limited warranty - 1 year , Technical support - phone consulting - 1 year
- 45 cm
- 36.4 cm
- 22.44 cm
- 5.61 kg
- Shipping Width
- 49.2 cm
- Shipping Depth
- 28.3 cm
- Shipping Height
- 41.3 cm
- Shipping Weight
- 7.19 kg
- Sound Emission
- 48 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.71 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.72 |
