HP OfficeJet 3830 Colour InkJet Multifunction Printer
Quicklinx: BPZKWS00 Mfr#: F5R95B#BEV
Get more done with the easiest way to print from your smartphone or tablet. Simplify tasks while saving time and money with this affordable, easy-to-use all-in-one with fax. It fits in nearly any space and works quietly in the background.
  • Get easy mobile printing
    Start printing and get connected quickly with easy setup from your smartphone, tablet or PC.Connect your smartphone or tablet directly to your printer – and easily print without accessing a network.Manage printing tasks and scan on the go with the free HP All-in-One Printer Remote mobile app.Easily print from a variety of smartphones and tablets. Your pages come out great – even if you're not there.
  • Get everything you need – right away
    Take charge of your tasks and finish in less time with the easy-to-use 5.5 cm (2.2-inch) display.Quickly copy, scan and fax multipage documents with the 35-page automatic document feeder.No need to wait – start printing right away with easy setup. Automatically connect to your wireless network.
  • Count on a product designed to fit your life
    Save your space with a compact all-in-one designed to fit on your desk, on a shelf or anywhere you need it.Print in any room you choose – without causing disruptions. Optional quiet mode helps keep noise to a minimum.
HP Officejet 3830 All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English / United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
100 - 250 pages
Max Copying Speed
Up to 7 ppm (mono) / up to 3.5 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 8.5 ppm (mono) / up to 6 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
2.2"
Original Size
216 x 297 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
215 x 355 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
AC 120/230 V (50/60Hz)
45 cm x 36.4 cm x 22.44 cm
5.61 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
1000 pages
100 - 250 pages
Display Diagonal Size
2.2"
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Maximum Copies
20
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI, PCLm
First Print Out Time B/W
14 sec
First Print Out Time Colour
17 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
PC Faxing
Fax Machine Features
Speed Dialing
50 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, Distinctive Ring Detection (DRD)
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
35 sheets
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
Supported Envelope Sizes
International DL (110 x 220 mm)
60 sheets
25 sheets
Input tray - 60 sheets - 215 x 355 mm weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 8.5 ppm - B/W (ISO) , Printing: up to 6 ppm - colour (ISO) , Copying: up to 7 ppm - B/W (ISO) , Copying: up to 3.5 ppm - colour (ISO) , Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 16 ppm (Letter A) - colour draft
1 x USB 2.0 - 4 pin USB Type B , 1 x modem - RJ-11
Operating System Support
MS Windows XP SP3, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
Software Included
Drivers & Utilities, HP Photo Creations
10 Watt
Power Consumption Standby
2.83 Watt
Power Consumption Sleep
1.17 Watt
Phone cable
Consumables Included
1 x ink cartridge (black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302
GOST, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - phone consulting - 1 year
45 cm
36.4 cm
22.44 cm
5.61 kg
Shipping Width
49.2 cm
Shipping Depth
28.3 cm
Shipping Height
41.3 cm
Shipping Weight
7.19 kg
Sound Emission
48 dBA (operating)
5 °C
20 - 80%
BPZK HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.68
BPZK HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.69
