HP Officejet 200 Mobile Printer
Quicklinx: C5ZVWS00 Mfr#: CZ993A#BHC
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Technology: Ink-jet
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
24 in stock
£163.79 ex VAT
£196.54 inc VAT
Make the world your office with powerful portable printing – no network necessary. This quick, quiet printer delivers more pages per cartridge and has a long-lasting battery life.
  • Easy portable printing wherever you need it
    Simply print from your laptop or mobile devices wirelessly, with or without a router.Start printing in minutes. HP Auto Wireless Connect makes setup easy.This durable, compact printer fits in your car, backpack, and more, for convenient printing anywhere.
  • Lead the way with fast, easy mobile printing
    Reduce charging interruptions with a long-lasting battery.Get the highest page yields of any other in-class printer, using Original HP cartridges.Set the pace for success wherever you go. Keep moving through the day with fast print speeds.Stay productive with a large and easy-to-use control panel.
  • High-powered quality and reliability
    Power through the workday. Charge from home, in your car or office, and more.Plug in your AC power source to charge within 90 minutes while the printer is off, with HP Fast Charge.Minimise disruptions with premium design and quiet performance. Impress clients, without noisy interruptions.Get high-quality prints time after time with a printer designed and built to be reliable.
HP Officejet 200 Mobile Printer - printer - colour - ink-jet
Printer Type
Personal printer - ink-jet - colour
Portable
2.1 kg
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, pigment black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 102 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 20 ppm - black draft - A4 (210 x 297 mm) , Up to 18 ppm - colour draft - A4 (210 x 297 mm) , Up to 9 ppm - black laser quality , Up to 6 ppm - colour laser quality
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
4800 x 1200 dpi
USB 2.0, USB host, Wi-Fi
AirPrint Enabled
Preview Screen Size
2"
RAM Installed (Max)
128 MB (128 MB)
Language Simulation
PCL 3
Media Type
Envelopes, transparencies, greeting cards, labels, plain paper, photo paper, index cards
Total Media Capacity
50 sheets
Monthly Duty Cycle (max)
500 pages
Recommended Monthly Volume
100 - 300 pages
Wireless network extender
AC 120/230 V
Linux, Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits)
36.4 cm x 18.6 cm x 6.9 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Print Speed
Built-in Devices
2.0" Hi-Res MGD
Preview Screen Size
2"
Wireless
AirPrint Enabled
1200 x 1200 dpi
4800 x 1200 dpi
First Print Out Time B/W
12 sec
Language Simulation
PCL 3
RAM
RAM Installed (Max)
128 MB / 128 MB (max)
Media Handling
Media Path Type
Straight
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 102 mm
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 76 x 102 mm
Borderless Photo Sizes
100 x 150 mm
Envelope Sizes
US A2 (111 x 146 mm), International DL (110 x 220 mm), Com-10 (105 x 241 mm), Monarch (98.4 x 190.5 mm)
Card / Label Sizes
2L (127 x 178 mm), 102 x 152 mm, 127 x 203.2 mm, 100 x 148 mm, 148 x 200 mm
Media Weight
60 g/m² - 300 g/m²
50 sheets
Media Feeders
1 x automatic - 50 sheets weight: 60 g/m² - 300 g/m²
Max Media Capacity
50 sheets
Duty Cycle
500 pages
100 - 300 pages
Security Protocols & Features
Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x ink cartridge (black) - HP 62 , 1 x ink cartridge (yellow/cyan/magenta) - HP 62
CSA, UL, VCCI, C-Tick, BSMI, GOST, EN 60950, GS, IEC950, CCC, EMC, MIC, FCC
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities, HP SureSupply
System Requirements Details
Windows 7 - HD 1 GB , Windows 7 64-bit Edition - HD 1 GB , Windows Vista - HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 850 MB , MacOS X 10.8/10.9/10.10 - HD 1 GB
Environmental Standards
ENERGY STAR
15 - 95%
36.4 cm
18.6 cm
6.9 cm
2.1 kg
Width (Shipping)
49.5 cm
Depth (Shipping)
24.3 cm
Height (Shipping)
11.9 cm
Weight (Shipping)
3.6 kg
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: C5ZV 041447
Condition: Customer return - item has been repaired under warranty by the manufacturer
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £72.93
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Printer
Wireless Capability: Wireless
Technology: Ink-jet
Brand: HP
Stock Status: Used Stock
Price Range Ex VAT: 150 - 300
