Brand
HP N223 21.5" 1920x1080 5ms VGA HDMI LED Monitor
Quicklinx: F9T4WS00 Mfr#: 3WP71AA#ABU
Experience crisp detail on the Full HD N223 54.61 cm (21.5") Monitor with a sharp 1920 x 1080 resolution. The convenient connectivity, adaptability, and affordable price point are ideal for everyday business.
  • Clear, detailed views
    See your work on an ample 54.61 cm (21.5") diagonal screen with Full HD 1920 x 1080 resolution and a 10M:1 Dynamic Contrast Ratio for a sharp, crisp viewing experience.
  • Create workspace comfort
    Establish a comfortable workspace with customizable tilt adjustment, an internal power supply, and mounting capabilities with the included 100mm VESA pattern to mount the display on a wall or to an arm or stand.
  • convenient connectivity
    Easily connect devices with centralized HDMI and VGA ports for digital access and legacy compatibility.
HP N223 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
600:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
50.4 cm x 20.12 cm x 38.3 cm
2.6 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, ICE
1-year warranty
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Mercury free, arsenic-free glass, 72% NTSC colour gamut
50.4 cm x 20.12 cm x 38.3 cm - with stand
2.6 kg
VGA , HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.5 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
18 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 50.4 cm - depth: 20.12 cm - height: 38.3 cm - weight: 2.6 kg , Without stand - width: 50.4 cm - depth: 4.9 cm - height: 31.05 cm - weight: 2.46 kg
Shipping Width
56.3 cm
Shipping Depth
11.9 cm
Shipping Height
44.7 cm
Shipping Weight
3.7 kg
ENERGY STAR Certified
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
Warranties (2)
F9T4 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.53
F9T4 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £30.10
Other bundles (1)
F9T4 HP Dual Head Keyed Cable Lock In Stock £43.00
