HP mt45 Ryzen 3 PRO 3300U 8GB 128GB 14" ThinPro OS
Quicklinx: F8PZWS00 Mfr#: 3JH21EA#ABU
Display Size: 14in
Processor Model: 2300U
Operating System: HP ThinPro
Installed Memory: 8GB
Hard Drive Capacity: 128GB
  • IEEE 802.11n
Hurry, only 3 left in stock!
£743.30 ex VAT
£891.96 inc VAT
Achieve the perfect balance of form and function with the beautifully designed HP mt45 Mobile Thin Client. It's offers built-in collaboration features such as a world-facing third mic, collaboration keys and loud speakers.
  • Distinctively designed to work everywhere
    Mobilize your workforce in style with this precision-crafted, all-aluminum mobile thin client. It has a breathtaking 14" diagonal Full HD narrow bezel and optional anti-glare touch display that's crisp and bright inside and outside.
  • Effortless remote conferencing
    Never miss a word during PC calls with advanced collaboration features like HP Noise Cancellation. Loud speakers expertly tuned by Bang & Olufsen produce rich sound, while the world-facing third microphone and Skype for Business collaboration keys boost productivity.
  • A privacy and security power combo
    Maximize data and device safety with HP Privacy Camera, multi-factor finger authentication, HP Sure Start Gen5BIOS protection and the secure, virus-resistant HP ThinPro OS.
  • Power-packed processing speeds
    Boost your performance with the next generation AMD Ryzen 3 PRO processor with Radeon Vega graphics, ideal for multi-tasking, streaming content and more.
HP Mobile Thin Client mt45 - 14" - Ryzen 3 Pro 2300U - 8 GB RAM - 128 GB SSD - UK
Mobile thin client
Operating System
HP ThinPro
AMD Ryzen 3 Pro 2300U / 2 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
128 GB SSD TLC
Display
14" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon Vega 6
Input Device
Keyboard, pointing stick, ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 5.0, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
32.6 cm x 23.43 cm x 1.79 cm
1.53 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile thin client
Operating System
HP ThinPro
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
RAM
8 GB (2 x 4 GB)
Max RAM Supported
8 GB
DDR4 SDRAM
Speed
2666 MHz / PC4-21300
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
128 GB SSD - (M.2 2280) SATA 6Gb/s - triple-level cell (TLC)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
45% NTSC colour gamut, Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
AMD Radeon Vega 6
Camera
Yes - HD
Video Resolutions
720p
Camera Features
IR camera, HP Privacy HD
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Noise-cancellation technology, Bang & Olufsen Audio
Input
Keyboard Layout
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 9260 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Miracast, dual stream (2x2)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, Bluetooth 5.0
3-cell Lithium Ion
50 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
USB-C , USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , HDMI , Headphone/microphone combo jack , Dock , LAN
Software
Software Included
Citrix ICA, Microsoft RDP, HP Device Manager, HP Hotkey Support, Windows Defender, VMware Horizon View, HP Secure Erase, Microsoft Internet Explorer 11, HP BIOS Config Utility, HP ThinUpdate, HP Easy Shell, HP Noise Cancellation, Native Miracast, HP USB Port Manager, HP Connection Optimizer, Power On Authentication, HP Write Manager, HP BIOSphere Gen5, HP SureStart Gen5
Case Material
Aluminum
Dockable
Security
Power-on password, Setup Password, BIOS Absolute Persistence, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Master Boot Record Security, BIOS Update via Network
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, CCC, FCC, MIL-STD 810G, Common Criteria EAL4+, KC, low halogen, ICCP, AUS/NZ
Localization
1.53 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP mt45 Ryzen 3 PRO 3300U 8GB 128GB 14 Bundle deal on HP mt45 Ryzen 3 PRO 3300U 8GB 128GB 14" ThinPro OS
£842.47
Display Size: 14in
Optical Storage: None
Graphics: AMD Radeon Vega 6
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: 500 - 750
