Fast print, scan, copy, and fax performance, plus robust, comprehensive security built for how you work. This MFP finishes key tasks faster and guards against threats. Original HP Toner cartridges with JetIntelligence give you more pages.
- HP LaserJet Pro MFP M426fdw - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Speed
- Up to 38 ppm
- Max Copying Resolution
- Up to 4800 x 600 dpi
- Max Printing Speed
- Up to 38 ppm
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 1200 dpi
- Display
- 3"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, light-weight paper, punched paper, preprinted paper
- Standard Media Capacity
- 350 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, save to network folder, scan to Cloud, Instant-on Technology
- Power
- AC 230 V (50/60Hz)
- 42 cm x 39 cm x 32.3 cm
- 12.86 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- 80000 pages
- 750 - 4000 pages
- Display Diagonal Size
- 3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Up to 38 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Fit to page, ID Card Copy
Printing
- Up to 38 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5, PCLm, URF, PWG
- Image Enhancement Technology
- HP FastRes 1200, HP ProRes 1200, HP ProRes 600
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- PC Faxing
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 119 stations
- Delayed Transmission
- Remote Fax Retrieval (Polling)
- Fax forwarding, activity report, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, block fax, poll receive, print fax log, billing codes
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 175 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 197 x 273 mm, 76.2 x 127 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm, 104.9 x 148.59 mm
- 350 sheets
- 100 sheets
- 150 sheets
- ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m² , Input tray - 250 sheets size: 104.9 x 148.6 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Output tray - 150 sheets
- Speed Details
- Scanning: up to 26 ppm (A4) - B/W , Scanning: up to 21 ppm (A4) - colour , Scanning: up to 26 ppm (Letter A) - B/W , Scanning: up to 21 ppm (Letter A) - colour , Scanning: up to 47 ipm (A4) - B/W , Scanning: up to 30 ipm (A4) - colour , Scanning: up to 47 ipm (Letter A) - B/W , Scanning: up to 30 ipm (Letter A) - colour , Printing: up to 38 ppm (A4) - B/W (ISO) , Printing: up to 40 ppm (Letter A) - B/W (ISO) , Printing: up to 30 ipm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 32 ipm (Letter A) - B/W duplex (ISO/IEC 24734) , Copying: up to 38 ppm (A4) - B/W (ISO) , Copying: up to 40 ppm (Letter A) - B/W (ISO) , Copying: up to 30 ppm (A4) - B/W (ISO/IEC 29183) , Copying: up to 32 ppm (Letter A) - B/W (ISO/IEC 29183) , Printing: up to 63 ppm (A5) - B/W draft , Printing: up to 14 ppm (A5) - B/W best
- 2 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- LDAP, SSL, Apple Bonjour, WEP, TLS, WPA, WPA2, 802.1x, TKIP, AES
- Operating System Support
- UNIX, Red Hat Linux 8.0, Red Hat Linux 9.0, Ubuntu Linux 10.04, Red Hat Enterprise Linux 5, Mandriva 2010, Red Hat Enterprise Linux 6, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Fedora 18, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, MS Windows XP 64-bit Edition SP3 or later, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, MEPIS 6.0 or later, Slackware Linux 9.0 or later, gOS 8.04.1, IGOS 1.0, Linpus Linux 9.4, Linpus Linux 9.5, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0 - 7.6, Mandriva 2011, MEPIS 6.5, MEPIS 7.0, MEPIS 8.0, PCLinuxOS 2006, PCLinuxOS 2007, PCLinuxOS 2008, PCLinuxOS 2009, Red Hat Enterprise Linux 7, Slackware Linux 9.1, Slackware Linux 10.0, Slackware Linux 10.1, Slackware Linux 10.2, Slackware Linux 11.0, Slackware Linux 12.0, Slackware Linux 12.1
- Software Included
- Drivers & Utilities
- Voltage Required
- 583 Watt
- Power Consumption Standby
- 9.1 Watt
- Power Consumption Sleep
- 2.7 Watt
- Included Accessories
- USB cable
- Consumables Included
- 1 x toner cartridge (black) - up to 3100 pages - HP 26A
- FCC Class B certified, ICES-003, FCC Part 15.247, RSS-210, FCC Part 68, CS-03, R&TTE, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CAN/CSA C22.2 No. 60950-1-07, GB 9254-2008, EN 61000-3-3:2008, IECEE CB, EN 61000-3-2:2006+A1:2009+A2:2009, NOM-151-SCTI-1999, IEC 60825-1:2007, EN 62479:2010, IEC 62311, 21 CFR 1040.10, 21 CFR 1040.11, GB 17625.1-2012, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, ETSI ES203 021, EN 55024:2010, CISPR 22:2008, IEC 60950-1:2005 + A1:2009, EN 62311:2008, IEC 62479:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 55022:2010 Class B
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 42 cm
- 39 cm
- 32.3 cm
- 12.86 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 15.5 kg
- Sound Emission
- 55 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
HP 26A Black Original Laserjet Toner | In Stock | £101.74 |
HP 26X High Yield Black Original LaserJet Toner Cartridge | In Stock | £173.58 |
