HP Mono LaserJet Pro MFP M426fdw
Quicklinx: BPMKWS00 Mfr#: F6W15A#B19
Fast print, scan, copy, and fax performance, plus robust, comprehensive security built for how you work. This MFP finishes key tasks faster and guards against threats. Original HP Toner cartridges with JetIntelligence give you more pages.
HP LaserJet Pro MFP M426fdw - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 38 ppm
Max Copying Resolution
Up to 4800 x 600 dpi
Max Printing Speed
Up to 38 ppm
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Display
3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, light-weight paper, punched paper, preprinted paper
Standard Media Capacity
350 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, save to network folder, scan to Cloud, Instant-on Technology
AC 230 V (50/60Hz)
42 cm x 39 cm x 32.3 cm
12.86 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
80000 pages
750 - 4000 pages
Display Diagonal Size
3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 38 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
Fit to page, ID Card Copy
Printing
Max Printing Speed
Up to 38 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, PCL 5, PCLm, URF, PWG
Image Enhancement Technology
HP FastRes 1200, HP ProRes 1200, HP ProRes 600
Automatic Duplexing
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
PC Faxing
Fax Machine Features
Speed Dialing
120 station(s)
Telephone / Fax Switch
Broadcast Transmission
119 stations
Delayed Transmission
Remote Fax Retrieval (Polling)
Fax forwarding, activity report, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, block fax, poll receive, print fax log, billing codes
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
175 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 197 x 273 mm, 76.2 x 127 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm, 104.9 x 148.59 mm
350 sheets
100 sheets
150 sheets
ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m² , Input tray - 250 sheets size: 104.9 x 148.6 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 38 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 40 ppm (Letter A) - B/W (ISO/IEC 24734) , Printing: up to 30 ipm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 32 ipm (Letter A) - B/W duplex (ISO/IEC 24734) , Copying: up to 38 ppm (A4) - B/W (ISO/IEC 29183) , Copying: up to 40 ppm (Letter A) - B/W (ISO/IEC 29183) , Scanning: up to 26 ppm (A4) - B/W , Scanning: up to 21 ppm (A4) - colour , Scanning: up to 26 ppm (Letter A) - B/W , Scanning: up to 21 ppm (Letter A) - colour , Scanning: up to 47 ipm (A4) - B/W , Scanning: up to 30 ipm (A4) - colour , Scanning: up to 47 ipm (Letter A) - B/W , Scanning: up to 30 ipm (Letter A) - colour , Copying: up to 30 ppm (A4) - B/W (ISO/IEC 29183) , Copying: up to 32 ppm (Letter A) - B/W (ISO/IEC 29183) , Printing: up to 63 ppm (A5) - B/W draft , Printing: up to 14 ppm (A5) - B/W best
2 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, SSL, Apple Bonjour, WEP, TLS, WPA, WPA2, 802.1x, TKIP, AES
Operating System Support
UNIX, Red Hat Linux 8.0, Red Hat Linux 9.0, Ubuntu Linux 10.04, Red Hat Enterprise Linux 5, Mandriva 2010, Red Hat Enterprise Linux 6, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Fedora 18, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, MS Windows XP 64-bit Edition SP3 or later, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, MEPIS 6.0 or later, Slackware Linux 9.0 or later, gOS 8.04.1, IGOS 1.0, Linpus Linux 9.4, Linpus Linux 9.5, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0 - 7.6, Mandriva 2011, MEPIS 6.5, MEPIS 7.0, MEPIS 8.0, PCLinuxOS 2006, PCLinuxOS 2007, PCLinuxOS 2008, PCLinuxOS 2009, Red Hat Enterprise Linux 7, Slackware Linux 9.1, Slackware Linux 10.0, Slackware Linux 10.1, Slackware Linux 10.2, Slackware Linux 11.0, Slackware Linux 12.0, Slackware Linux 12.1
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
583 Watt
Power Consumption Standby
9.1 Watt
Power Consumption Sleep
2.7 Watt
USB cable
Consumables Included
1 x Cartridge (black) - up to 3100 pages - HP 26A
FCC Class B certified, ICES-003, FCC Part 15.247, RSS-210, FCC Part 68, CS-03, R&TTE, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CAN/CSA C22.2 No. 60950-1-07, GB 9254-2008, EN 61000-3-3:2008, IECEE CB, EN 61000-3-2:2006+A1:2009+A2:2009, NOM-151-SCTI-1999, IEC 60825-1:2007, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 62479:2010, IEC 62311, 21 CFR 1040.10, 21 CFR 1040.11, GB 17625.1-2012, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, ETSI ES203 021, EN55022:2010 Class B, EN 55024:2010, CISPR 22:2008, IEC 60950-1:2005 + A1:2009, EN 62311:2008, IEC 62479:2010
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
42 cm
39 cm
32.3 cm
12.86 kg
Shipping Width
49.7 cm
Shipping Depth
39.8 cm
Shipping Height
49 cm
Shipping Weight
15.5 kg
Sound Emission
55 dBA (operating)
15 °C
32.5 °C
10 - 80%
BPMK HP 26A Black Original Laserjet Toner In Stock £84.92
BPMK HP 26X High Yield Black Original LaserJet Toner Cartridge In Stock £145.50
