HP Mobile Thin Client AMD A8-8600B 4GB 32GB 14" Windows Embedded 7 32-bit
Quicklinx: BXY5WS00 Mfr#: N9Z95AA#ABU
  • Bluetooth 4.0
  • IEEE 802.11n
Take your workload by the horns with the HP mt42 Mobile Thin Client, HP's thinnest, lightest, and most powerful mobile thin client. Access the cloud and your virtual desktop with Windows 10 IoT Enterprise for Thin Clients on a stylish and fully-loaded design without the bulk.
  • Super-charged data delivery
    Improve wired and Wi-Fi network performance and the end user experience with HP Velocity software.
  • Next-level security
    Help ensure data security by keeping it off the local device, and get added protection from the TPM chipset and Windows with Write Filter.
  • Management simplified
    Make it easy to deploy, manage, and maintain your install base with HP Device Manager.
  • Quick. Clean. Streamlined
    Simplify the HP Thin Client Windows Embedded user experience with HP Easy Shell's customized interface and protection for targeted cloud control.
  • Work with what you know on the go
    Feel right at home and make life easier for IT administrators with Windows 10 IoT Enterprise for Thin Clients, which supports Microsoft Office 365 and your peripheral drivers.
  • Designed-in communication tools
    Easily collaborate with Ethernet and wireless networking, broadened unified communications support, and integrated audiovisual features.
HP Mobile Thin Client mt42 - 14" - AMD A8 - PRO-8600B - 4 GB RAM - 32 GB SSD - UK
Mobile thin client
Operating System
Win Embedded Standard 7E 32-bit - English
AMD A8 PRO-8600B / 1.6 GHz, up to 3 GHz
4 GB DDR3L (1 x 4 GB)
Storage
32 GB SSD
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon R6
Input Device
Keyboard, touchpad
Keyboard
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
33.8 cm x 23.7 cm x 1.89 cm
1.54 kg
Environmental Standards
- EPEAT Climate+
Mobile thin client
Operating System
Microsoft Windows Embedded Standard 7E 32-bit - English
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
Quad-Core
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
8 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
32 GB SSD M.2 SATA 6Gb/s
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare +PSR
Audio & Video
Graphics Processor
AMD Radeon R6
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3228
DTS Studio Sound
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, touchpad
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Broadcom BCM5762
IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, Bluetooth 4.0
3-cell Lithium Ion
46 Wh
AC Adapter
Input
Output
45 Watt, 9.5 V
Connections & Expansion
Slots
1 x Micro-SIM card (1 free)
Interfaces Details
USB-C , USB 3.0 , VGA , LAN , DisplayPort , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
HP Device Manager, HP Velocity, HP Easy Shell
Dockable
Security
TPM Enhanced DriveLock, 1 USB 3.0 charging port, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
1.54 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
