Maximize your workspace with the Mini-in-One display that fully encloses a USFF PC and is purpose-built to seamlessly connect, contain, secure, and power your Mini - from this generation to the next. Multi-task like a pro in Full HD resolution, and add your USB devices at the display.
Stylish, adaptable design
Take your clean desk to another level with an elegant design and simple slide-in mechanism that connects your Mini behind the screen through a USB-C cable and houses both discreetly out of view. Then power on your solution through the display. -
Security for your Mini, privacy for you
Reduce the threat of tampering with the built-in, fully-enclosed compartment and panels that secure your Mini. Work without worry that you're being watched with the integrated HP Privacy Camera shutter that blocks your webcam feed when not in use. -
Expansive HP Mini compatibility and device connectivity
Effortlessly support your evolving business with separate display and PC lifecycles with our first display that powers a USFF PC with up to 65 watts. Add an HP Pro or Elite Desktop Mini through a USB-C cable and USB devices through 6 USB ports.
- HP Mini-in-One 24 - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class E
- Power Consumption (On mode)
- 17.8 W
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 800000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey), 5 ms (overdrive)
- Colour Gamut
- 72% NTSC
- Input Connectors
- DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver (stand)
- 53.96 cm x 24.2 cm x 50.38 cm
- 7.2 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, ICE
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93.24
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 3-sided micro-edge, 72% NTSC colour gamut
- 53.96 cm x 24.2 cm x 50.38 cm - with stand
- 7.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort (HDCP) , USB 3.1 Gen 1 upstream (Type B) , 6 x USB 3.1 Gen 1 downstream (Type A) , USB-C 3.1 Gen 1 (HDCP) , Audio line-in , Audio line-out
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 17.8 W
- Power Consumption SDR (On mode)
- 17.8 kWh/1000h
- Power Consumption (Typical)
- 50 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 53.96 cm - depth: 24.2 cm - height: 50.38 cm - weight: 7.2 kg , Without stand - width: 53.96 cm - depth: 7.5 cm - height: 36.76 cm - weight: 4.06 kg
- Shipping Width
- 65 cm
- Shipping Depth
- 47.3 cm
- Shipping Height
- 31.5 cm
- Shipping Weight
- 12.78 kg
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80%
