HP Mini-in-One 24" 1920x1080 5ms DisplayPort USB-C IPS LED Monitor
Quicklinx: FRPCWS00 Mfr#: 7AX23AT#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 14ms
Speakers: Speaker(s)
Interfaces: USB-C, DisplayPort
£320.81 ex VAT
£384.97 inc VAT
Maximize your workspace with the Mini-in-One display that fully encloses a USFF PC and is purpose-built to seamlessly connect, contain, secure, and power your Mini - from this generation to the next. Multi-task like a pro in Full HD resolution, and add your USB devices at the display.
  • Stylish, adaptable design
    Take your clean desk to another level with an elegant design and simple slide-in mechanism that connects your Mini behind the screen through a USB-C cable and houses both discreetly out of view. Then power on your solution through the display.
  • Security for your Mini, privacy for you
    Reduce the threat of tampering with the built-in, fully-enclosed compartment and panels that secure your Mini. Work without worry that you're being watched with the integrated HP Privacy Camera shutter that blocks your webcam feed when not in use.
  • Expansive HP Mini compatibility and device connectivity
    Effortlessly support your evolving business with separate display and PC lifecycles with our first display that powers a USFF PC with up to 65 watts. Add an HP Pro or Elite Desktop Mini through a USB-C cable and USB devices through 6 USB ports.
HP Mini-in-One 24 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
17.8 W
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 800000:1 (dynamic)
Response Time
14 ms (grey-to-grey); 5 ms (overdrive)
Input Connectors
DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Black, silver (stand)
53.96 cm x 24.2 cm x 50.38 cm
7.2 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, ICE
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93.24
Brightness
250 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
72% NTSC colour gamut, Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 3-sided micro-edge
53.96 cm x 24.2 cm x 50.38 cm - with stand
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort (HDCP) , USB 3.1 Gen 1 upstream (Type B) , 6 x USB 3.1 Gen 1 downstream (Type A) , USB-C 3.1 Gen 1 (HDCP) , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
17.8 W
17.8 kWh/1000h
Power Consumption (Typical)
50 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 53.96 cm - depth: 24.2 cm - height: 50.38 cm - weight: 7.2 kg , Without stand - width: 53.96 cm - depth: 7.5 cm - height: 36.76 cm - weight: 4.06 kg
Shipping Width
65 cm
Shipping Depth
47.3 cm
Shipping Height
31.5 cm
Shipping Weight
12.78 kg
TCO Certified
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
FRPC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £15.53
FRPC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £30.10
FRPC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.64
FRPC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £6.01
Response Time: 14ms
Interfaces: USB-C
Interfaces: DisplayPort
Brand: HP
