Product
HP Main Battery Pack 11.1v 4200mAh
Quicklinx: 9FJTWS00 Mfr#: CBI3276A
Device Type: Laptop
Device Screen Size: [N/A]
£49.60 ex VAT
£59.52 inc VAT
Main Battery Pack 11.1v 4200mAh , (6-cell) Black
Standard battery life
204mm x 52mm x 26mm
Weight: 266g
2-Power Main Battery Pack - laptop battery - Li-Ion - 4200 mAh
Laptop battery
266 g
Lithium Ion - 4200 mAh
Battery Form Factor
Internal
Batteries Qty
1
20.4 cm x 5.2 cm x 2.6 cm
Acer Aspire ONE D260
Laptop battery
Battery Enclosure Type
Internal
Quantity
1
Lithium Ion
Voltage Provided
11.1 V
4200 mAh
20.4 cm
5.2 cm
2.6 cm
266 g
Acer Aspire ONE D260, D260-13686, D260-13992, D260-13D, D260-13Dk, D260-13Dpu, D260-13DQss_W7625, D260-2028, D260-2097, D260-2344, D260-2364, D260-2382, D260-2455, D260-2Bkk, D260-2Bkk16, D260-2BQkk, D260-2BQpu_XP316, D260-2BQss, D260-2BQuu_XP316, D260-2Bss, D260-2Bss16, D260-2Buu, D260-2Buu16, D260-2DGkk, D260-2DGpu, D260-2DGss, D260-2Dkk, D260-2Dkk16, D260-2Dkk25, D260-2Dkk25BT, D260-2Dpu, D260-2Dpu25 BT, D260-2DQkk_W7625, D260-2DQpu_W7625, D260-2DQss_W7625, D260-2DQuu_W7625, D260-2Ds, D260-2Dss, D260-2Dss16, D260-2Dss25, D260-2Dss25BT, D260-2Du, D260-2Du25BT, D260-2Duu, D260-2Duu16, D260-2Duu25, D260B, D260-Cg, D260-DB, D260P, D260-Pu, D260S
HP Main Battery Pack 11.1v 4200mAh Bundle deal on HP Main Battery Pack 11.1v 4200mAh
£144.61
Device Type: Laptop
Brand: HP
Price Range Ex VAT: 0 - 50
