Ideal for enterprises and medium businesses that need a secure, highly productive, energy-efficient colour MFP.
High-speed performance meets energy efficiency
Don't wait for documents. Print your first page in as few as 9 seconds from energy-efficient sleep mode.Speed through jobs. Print two sides as quickly – as one – up to 38 ipm – and scan both sides of the page at once.This MFP uses exceptionally low amounts of energy – thanks to its innovative design and toner technology.Choose a maximum capacity of up to 2,300 sheets. Print up to 59 pages per minute on A5. -
Unparalleled fleet security and management
Embedded features detect security threats and heal your MFP, protecting it from boot up to shutdown.Protect sensitive data on the MFP and in transit, using embedded security features and 256-bit encryption.Protect sensitive business data with embedded and optional HP JetAdvantage Security Solutions.Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency. -
More
Make an impression with leading colour quality from HP. Get unparalleled printing for your office needs.Get more pages with each Original HP Toner cartridge with JetIntelligence and high-yield cartridges.Help ensure the Original HP quality you paid for with anti-fraud and cartridge authentication technology.Print right away with preinstalled toner cartridges. Replace them with cartridges featuring auto seal removal. -
Stay connected with secure mobile printing options
Use optional, 128-bit encrypted wireless direct printing from mobile devices – no network needed.Add the option to print with a touch of your NFC-enabled mobile device to this printer – no network needed.Easily print from a variety of smartphones and tablets – generally no setup or apps required.Easily access, print, and share resources with Ethernet and optional wireless networking.
- HP LaserJet Enterprise MFP M577dn - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Max Copying Speed
- Up to 38 ppm (mono) / up to 38 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper, preprinted paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 2300 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, security lock slot
- Power
- AC 230 V (50Hz)
- 48.2 cm x 50.4 cm x 58.3 cm
- 38.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Laser - colour
- 80000 pages
- 2000 - 7500 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.75 GB
- Max Supported Memory
- 2.5 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- ID Card Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.7
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 5.6 sec
- First Print Out Time Colour
- 6.9 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), 76 x 127 mm
- 650 sheets
- 2300 sheets
- 100 sheets
- 250 sheets
- ADF - 100 sheets - Legal (216 x 356 mm) , Input tray - 550 sheets size: 102 x 148 mm - 216 x 297 mm weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 38 ppm (A4) - B/W normal , Printing: up to 38 ppm (A4) - colour normal , Printing: up to 40 ppm (Letter A) - B/W normal , Printing: up to 40 ppm (Letter A) - colour normal , Printing: up to 59 ppm (A5) - B/W , Printing: up to 59 ppm (A5) - colour , Printing: up to 38 ppm (A4) - B/W duplex , Printing: up to 38 ppm (A4) - colour duplex , Printing: up to 40 ppm (Letter A) - B/W duplex , Printing: up to 40 ppm (Letter A) - colour duplex , Scanning: up to 43 ppm (A4) - B/W normal , Scanning: up to 43 ipm (A4) - B/W normal , Scanning: up to 38 ppm (A4) - colour normal , Scanning: up to 38 ipm (A4) - colour normal , Copying: up to 38 ppm (A4) - B/W normal , Copying: up to 38 ppm (A4) - colour normal , Copying: up to 40 ppm (Letter A) - B/W normal , Copying: up to 40 ppm (Letter A) - colour normal , Copying: up to 38 ppm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - colour duplex , Copying: up to 40 ppm (Letter A) - B/W duplex , Copying: up to 40 ppm (Letter A) - colour duplex
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A
- SSL, TLS, IPsec, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise
- Operating System Support
- UNIX, MS Windows XP SP3, MS Windows Vista, Ubuntu Linux 10.04, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Android, iOS, Fedora 18, openSUSE 12.2, openSUSE 12.3, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Apple Mac OS X 10.9, Windows RT 8.1, Fedora 19, MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, Windows RT 8, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), openSUSE 13.1 (32/64-bit), Ubuntu Linux 13.10, Windows 10 (32/64-bits), Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0.x
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 592 Watt
- Power Consumption Standby
- 47.3 Watt
- Power Consumption Sleep
- 3.48 Watt
- First Copy Out Time B/W
- 5.6 sec
- First Copy Out Time Colour
- 9.1 sec
- Consumables Included
- 1 x Cartridge (black) - up to 6000 pages , 1 x Cartridge (cyan) - up to 5000 pages , 1 x Cartridge (magenta) - up to 5000 pages , 1 x Cartridge (yellow) - up to 5000 pages
- UL, cUL, GS, IEC 60950-1, EN 60950-1, EN 60825-1, CAN/CSA C22.2 No. 60950-1-07, EN 62479:2010
- Security Slot Type
- Kensington security slot
- ENERGY STAR Certified
- Limited warranty - 1 year
- 48.2 cm
- 50.4 cm
- 58.3 cm
- 38.1 kg
- Shipping Width
- 75.5 cm
- Shipping Depth
- 65 cm
- Shipping Height
- 60 cm
- Shipping Weight
- 44.4 kg
- Sound Emission
- 32 dBA (idle) / 51 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
HP 87A Black Original LaserJet Toner Cartridge | In Stock | £162.30 |
HP 87X High Yield Black Original LaserJet Toner Cartridge | In Stock | £220.69 |
