HP LD5511 55" Class (54.64" viewable) LED display
Quicklinx: CKJSWS00 Mfr#: T5X84AA#ABU
Video Interface: Component, HDMI
TV Tuner Presence: No
  • 1080p
£1,090.59 ex VAT
£1,308.70 inc VAT
Collaborate and conference in eye-popping style with the HP LD5511 139 cm (55") Large Format Display, which transforms your meeting room into a world-class conference center and delivers exceptional clarity and brilliant colors.
Fantastic front of screen
View content from virtually any corner with the 55" diagonal Full HD screen and 178° viewing angles. High brightness and contrast ratio provide excellent picture quality and readability that’s perfect for meeting rooms that seat up to 12.
Create a complete conferencing solution.
Pair with an HP Elite Slice for Meeting Rooms, HP Collaboration PC with Intel® Unite™ software or HP Chromebox and interact seamlessly with co-workers or clients on an extra-large display that has integrated speakers for crystal clear audio.
Designed for the long haul.
Rest assured with a display that has commercial-grade display components and is ready to run in demanding environments. Best of all, it’s supported by a three-year standard limited warranty and optional HP Care services.
HP LD5511 55" Class (54.64" viewable) LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.64"
Commercial Use
Yes - digital signage
Country Kits
United Kingdom
Resolution
1920 x 1080
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
IPS
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control
Voltage
141 Watt
Power Consumption Stand by
0.5 Watt
123.86 cm x 32.96 cm x 75.17 cm
17.87 kg
Manufacturer Selling Program
HP Smart Buy
141 Watt
Diagonal Class
55"
Diagonal Size
54.64"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Dimensions
With stand
123.86 cm
32.96 cm
75.17 cm
17.87 kg
Enclosure Colour
HP Smart Buy
Country Kits
United Kingdom
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Direct-lit LED
Coating
Anti-glare
Image Contrast Ratio
1200:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Display Menu Language
Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 200 mm, 400 x 400 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1280 x 720, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1600 x 900
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Network & Internet Multimedia
LAN
Connector Type
VGA input , HDMI , VGA output , DVI-D input , Audio line-in , USB , LAN , Audio line-out , Component video input , Remote control input , Remote control output , Audio line-out
VGA cable - 1.8 m , HDMI cable - 1.8 m
Plug and Play, UL, VCCI, C-Tick, BSMI, TUV S, CB, CCC, PSB, FCC, TUV Bauart, EAC, CE/EMC
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Dimensions & Weight Details
Panel without stand - 123.86 cm x 6.17 cm x 71.11 cm x 16 kg
5 °C
20 - 80% (non-condensing)
Video Interface: HDMI
Brand: HP
Price Range Ex VAT: £1000 - £1500
