Ramp up your business efficiency and print in sizes up to A3 with ease. HP Managed MFPs and printers are optimized for managed environments. Offering increased monthly page volumes and fewer interventions, this portfolio of products can help reduce printing and copying costs.
Expand your options with sharp A3 printing
Empower your teams to do more – print, scan, copy and fax on paper sizes up to A3 – from a desktop-sized MFP.
Stay focused on work – paper capacity up to 4,600 sheets and high-capacity cartridges limit interruptions.
Get impressive document quality with near edge-to-edge printing and a convenient, built-in stapler.
Print what you need, even on the go – from your smartphone or tablet – using HP ePrint or Apple AirPrint™.
Quicken your business pace
Streamline tasks – print, scan, copy and fax projects directly at the MFP's large colour touchscreen.
Save time by launching one-touch workflows with HP Quick Sets.
Get just the results you need – using touchscreen controls to preview, edit and reorder scans at the device.
Easily send scanned files to a fax, folder, email or USB. Print right from a memory device via the USB port.
Manage and protect your fleet for the long run
Simplify fleet management using industry-leading tools such as HP Web Jetadmin and reliably safeguard devices.
Safeguard data – at rest or in transit – with an encrypted hard drive, user authentication and security features.
Add security tools – such as card and badge readers – via the hardware integration pocket.
Extend the capabilities of workteam print environments, using a rich array of easy-to-integrate solutions.
Save energy and reduce your environmental impact
Reduce energy use with HP Auto-On/Auto-Off Technology, and conserve power with Instant-on Technology.
Save paper and cut costs, using automatic two-sided printing.
Easily recycle Original HP LaserJet toner cartridges through HP Planet Partners.
Empower your teams to do more - print, scan, copy and fax on paper sizes up to A3 - from a desktop-sized MFP. Stay focused on work - paper capacity up to 4,600 sheets and high-capacity cartridges limit interruptions. Get impressive document quality with near edge-to-edge printing and a convenient, built-in stapler. Print what you need, even on the go - from your smartphone or tablet - using HP ePrint or Apple AirPrint. -
Streamline tasks - print, scan, copy and fax projects directly at the MFP's large color touchscreen. Save time by launching one-touch workflows with HP Quick Sets. Get just the results you need - using touchscreen controls to preview, edit and reorder scans at the device. Easily send scanned files to a fax, folder, email or USB. Print right from a memory device via the USB port. -
Simplify fleet management using industry-leading tools such as HP Web Jetadmin and reliably safeguard devices. Safeguard data - at rest or in transit - with an encrypted hard drive, user authentication and security features. Add security tools - such as card and badge readers - via the hardware integration pocket. Extend the capabilities of workteam print environments, using a rich array of easy-to-integrate solutions. -
Reduce energy use with HP Auto-On/Auto-Off Technology, and conserve power with Instant-on Technology. Save paper and cut costs, using automatic two-sided printing.
- HP LaserJet Managed MFP M725dnm - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 375000 pages
- Recommended Monthly Volume
- 5000 - 40000 pages
- Max Copying Speed
- Up to 41 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 41 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 68 x 148 mm (min) - A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76.2 x 127 mm (min) - 312 x 469.9 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, vellum paper, card stock, light-weight paper, preprinted paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 4600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host (internal), USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, Hardware Integration Pocket, Foreign Interface Harness (FIH)
- Power
- AC 230 V (50/60Hz)
- 61.4 cm x 64.9 cm x 60.9 cm
- 54.11 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Laser - monochrome
- 375000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1 GB
- Max Supported Memory
- 1.5 GB
Copying
- Max Copying Speed
- Up to 41 ppm
- Maximum Copies
- 9999
Printing
- Up to 41 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.4, PCL 5
- First Print Out Time B/W
- 10 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 68 x 148 mm
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 45 g/m²
- Max Media Weight
- 199 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 76.2 x 127 mm, JIS B6 (128 x 182 mm), 297 x 363 mm, 312 x 469.9 mm, 297 x 431 mm
- 600 sheets
- 4600 sheets
- 100 sheets
- 250 sheets
- RADF - 100 sheets size: 68 x 148 mm - A3 (297 x 420 mm) weight: 45 g/m² - 199 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - 312 x 469.9 mm weight: 60 g/m² - 199 g/m² , Input tray - 250 sheets size: A5 (148 x 210 mm) - 297 x 363 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: A5 (148 x 210 mm) - 297 x 431 mm weight: 60 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 41 ppm (A4) - B/W , Printing: up to 28 ipm (A4) - B/W duplex , Printing: up to 20 ppm (A3) - B/W , Copying: up to 41 ppm (A4) , Scanning: up to 50 ppm - B/W , Scanning: up to 30 ppm - colour , Scanning: up to 19 ipm - B/W duplex , Scanning: up to 14 ipm - colour duplex
- 2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host (internal)
- Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise
- Operating System Support
- MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 (32/64-bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- 890 Watt
- Power Consumption Standby
- 39 Watt
- Power Consumption Sleep
- 6.5 Watt
- Consumables Included
- 1 x Cartridge (black) - up to 10000 pages
- EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:1998 + A1 + A2, EMC 2004/108/EC, EN55022:2010 Class A, CISPR 22:2008
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 61.4 cm
- 64.9 cm
- 60.9 cm
- 54.11 kg
- Shipping Width
- 76 cm
- Shipping Depth
- 74.5 cm
- Shipping Height
- 83.2 cm
- Shipping Weight
- 68.6 kg
- Sound Emission
- 54 dBA (operating)
- 10 °C
- 32.5 °C
- 30 - 70%
