HP Color LaserJet Finishers improve workflow management by upgrading your printer to automatic stapling and sheet stacking. Monitor your printer less frequently with convenient automatic job stapling and sorting in the additional output bin.
Speed up productivity and save time by streamlining workflow processes with automatic stapling. Staple up to 15 pages per document and get job collation and sorting in the process.
Expand your printer's output capacity and accommodate multiple users' jobs with this large 500-sheet tray .
Save time finding your print job with jobs sorted into neat stacks.
- HP Stapler/Stacker - punch unit
- Product Type
- Punch unit
- Punching Type
- 2/4-hole
- Designed For
- Color LaserJet Enterprise M855dn, M855x+, M855x+ NFC/Wireless direct, M855xh; Color LaserJet Managed Flow MFP M880zm, MFP M880zm+; LaserJet Enterprise Flow MFP M880z, MFP M880z+, MFP M880z+ NFC/Wireless direct
- Product Type
- Punch unit
- Punching Type
- 2/4-hole
- Shipping Dimensions (WxDxH) / Weight
- 158.8 cm x 109.5 cm x 84.8 cm / 113.2 kg
- Designed For
- HP Color LaserJet Enterprise M855dn, M855x+, M855x+ NFC/Wireless direct, M855xh , HP Color LaserJet Managed Flow MFP M880zm, MFP M880zm+ , HP LaserJet Enterprise Flow MFP M880z, MFP M880z+, MFP M880z+ NFC/Wireless direct
