Easy to install, this affordable, full-featured MFP prints, copies, scans and faxes. Enable easy printing from smartphones, tablets and laptops – at work, home, or on the go – with wireless connectivity and mobile printing features.
Handle the essentials with one affordable, networked MFP
Easily manage your MFP from the 7.6 cm (3-inch) colour touchscreen. Use the simple, intuitive control panel to set up projects easily and start printing right away.Finish projects fast – print documents at up to 20 ppm and get a first page out in as fast as 9.5 seconds with Instant-On Technology. Use the 35-page automatic document feeder to make the most of your time.Easily copy both sides of a two-sided ID or other small document onto the front of a single-page.Keep up with the pace of business with an MFP that prints, copies, faxes and scans. -
Print on your terms: from your smartphone, tablet and PC
Extend your printing reach. Easily set up, print, and share using Ethernet and wireless connectivity.Connect to your wireless printer in a snap using wireless direct printing.Print from your mobile device with built-in print capability or HP ePrint app and software.Print from virtually anywhere with AirPrint . -
Get going with no delays: this fast printer offers ease-of-use and energy savings
Spend less time at your MFP and more with your customers. Print, copy, and scan at high speeds that keep up with the pace of business.Help save energy with HP Instant-on Technology and HP Auto-On/Auto-Off Technology.
- HP LaserJet Pro MFP M127fn - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 8000 pages
- Recommended Monthly Volume
- 250 - 2000 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to application
- Power
- AC 230 V (50/60Hz)
- 42 cm x 36.5 cm x 30.9 cm
- 9.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- 8000 pages
- 250 - 2000 pages
- Display
- 2 lines
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 20 ppm
- Printer Drivers / Emulations
- PCL
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 9.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 500 pages
- Fax Printing Speed
- Up to 20 ppm
- Fax Printing Resolution
- 300 x 300 dpi
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling
Document & Media Handling
- Max Original Size
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 100 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 21 ppm (Letter A) - B/W normal , Printing: up to 20 ppm (A4) - B/W normal , Copying: up to 21 ppm (Letter A) - B/W normal , Copying: up to 20 ppm (A4) - B/W normal , Scanning: up to 7 ppm (A4) - B/W normal , Scanning: up to 5 ppm (A4) - colour normal
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Operating System Support
- Linux, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1
- Software Included
- Drivers & Utilities, HP Toolbox
- Voltage Required
- 480 Watt
- Power Consumption Standby
- 4.5 Watt
- Power Consumption Sleep
- 1.1 Watt
- First Copy Out Time B/W
- 15 sec
- Included Accessories
- USB cable, phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- UL, cUL, GS, ICES-003, EN55024, CISPR 22, EN55022 Class B, Laser Class 1, IEC 60950-1, FCC CFR47 Part 15 B, EN 60825-1, Directive 2004/108/EC, GB 9254-2008, Directive 2006/95/EC, EN 61000-3-3:2008, GB 17625.1-2003 EMC, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, IEC 60825-1:2007
- ENERGY STAR Certified
- Limited warranty - 1 year
- 42 cm
- 36.5 cm
- 30.9 cm
- 9.1 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 35 cm
- Shipping Weight
- 11.5 kg
- Sound Emission
- 52 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
HP 83A Black Original LaserJet Toner Cartridge | In Stock | £55.93 |
