Your basket is empty
HP LaserJet Pro Mono Multifunction Printer
Quicklinx: 9DYSWS00 Mfr#: CZ181A#B19
Easy to install, this affordable, full-featured MFP prints, copies, scans and faxes. Enable easy printing from smartphones, tablets and laptops – at work, home, or on the go – with wireless connectivity and mobile printing features.
HP LaserJet Pro MFP M127fn - multifunction printer (B/W)
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to application
AC 230 V (50/60Hz)
42 cm x 36.5 cm x 30.9 cm
9.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
8000 pages
250 - 2000 pages
Display
2 lines
USB 2.0, LAN
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
128 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Printer Drivers / Emulations
PCL
Image Enhancement Technology
HP FastRes 1200
First Print Out Time B/W
9.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 500 pages
Fax Printing Speed
Up to 20 ppm
Fax Printing Resolution
300 x 300 dpi
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling
Document & Media Handling
Max Original Size
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
150 sheets
100 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 21 ppm (Letter A) - B/W normal , Printing: up to 20 ppm (A4) - B/W normal , Copying: up to 21 ppm (Letter A) - B/W normal , Copying: up to 20 ppm (A4) - B/W normal , Scanning: up to 7 ppm (A4) - B/W normal , Scanning: up to 5 ppm (A4) - colour normal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
Linux, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1
Software Included
Drivers & Utilities, HP Toolbox
AC 230 V (50/60Hz)
480 Watt
Power Consumption Standby
4.5 Watt
Power Consumption Sleep
1.1 Watt
First Copy Out Time B/W
15 sec
USB cable, phone cable
Consumables Included
1 x Cartridge (black) - up to 700 pages
UL, cUL, GS, ICES-003, EN55024, CISPR 22, EN55022 Class B, Laser Class 1, IEC 60950-1, FCC CFR47 Part 15 B, EN 60825-1, Directive 2004/108/EC, GB 9254-2008, Directive 2006/95/EC, EN 61000-3-3:2008, GB 17625.1-2003 EMC, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, IEC 60825-1:2007
ENERGY STAR Certified
Limited warranty - 1 year
42 cm
36.5 cm
30.9 cm
9.1 kg
Shipping Width
49.7 cm
Shipping Depth
39.8 cm
Shipping Height
35 cm
Shipping Weight
11.5 kg
Sound Emission
52 dBA (operating)
15 °C
32.5 °C
10 - 80%
9DYS HP 83A Black Original LaserJet Toner Cartridge In Stock £47.19
