HP LaserJet Pro MFP M26nw
Quicklinx: CD8VWS00 Mfr#: T0L50A#B19
Print, scan and copy with proven reliability using the cheapest compact wireless laser multifunction printer from HP. Achieve professional quality and performance you expect.
Outstanding reliable quality without compromise
Easily print high-quality documents and with the reliability you expect from the leader in laser printing. Print directly from the start with a pre-installed cassette and an intuitive LED panel. HP Auto-On / Auto-Off technology helps to save energy.
Maximum productivity for business in compact format
Stay productive. Quickly and easily print, scan and copy documents with an efficient, compact laser multifunction printer designed to fit on small workspaces. This multifunction printer from HP provides high-quality results with HP toner cartridges.
The well-connected multifunction printer to match your work style
Provides consistent results that you can trust. Manage jobs from your mobile device, with or without a network. With mobile printing options, you can produce high-quality printing from virtually anywhere.
  • Outstanding, reliable quality without compromises
    Time after time, count on documents with sharp black text from the industry leader in laser printing.Tackle tasks quickly and easily – with the simple control panel.Help save energy with HP Auto-On/Auto-Off Technology.Start printing right out of the box, using a preinstalled Original HP LaserJet toner cartridge.
  • Big-time business productivity in a compact size
    Stay productive with print speeds up to 18 pages per minute.Print, scan, and copy with a compact laser printer that accommodates tight workspaces.Get high-quality pages and the performance you can count on with Original HP toner cartridges.
  • The well-connected MFP to match the way you work
    Easily access, print, and share resources with Ethernet and wireless networking.Easily print from mobile devices with Android version 4.4 or later or Google Chrome operating systems.Print directly from your mobile device – without accessing the network.Print from virtually anywhere with HP ePrint.
HP LaserJet Pro MFP M26nw - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
5000 pages
Recommended Monthly Volume
100 - 1000 pages
Max Copying Speed
Up to 18 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 18 ppm
Max Printing Resolution
Up to 1200 dpi
Scanning
1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, cards, labels
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN
Office Machine Features
Security lock slot
AC 230 V (50/60Hz)
42 cm x 26.6 cm x 25.4 cm
8.3 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - monochrome
5000 pages
100 - 1000 pages
USB 2.0, LAN
Security lock slot
Standard Memory
128 MB
Copying
Max Copying Speed
Up to 18 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 1200 dpi
Max Printing Speed
Up to 18 ppm
Printer Drivers / Emulations
PCLm, PCLms
First Print Out Time B/W
9.2 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm), DL (210 x 99 mm)
150 sheets
100 sheets
Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
Wi-Fi Direct
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
255 Watt
Power Consumption Standby
2.2 Watt
Power Consumption Sleep
1.4 Watt
Consumables Included
1 x toner cartridge (black) - up to 500 pages
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55022:2010 CISPR 22:2008 Class B, EN 55024:2010
Security Slot Type
Kensington security slot
ENERGY STAR Certified
42 cm
26.6 cm
25.4 cm
8.3 kg
Shipping Width
49.7 cm
Shipping Depth
33.2 cm
Shipping Height
35 cm
Shipping Weight
10.3 kg
Sound Emission
47 dBA (operating)
15 °C
32.5 °C
10 - 80%
