Print, scan and copy with proven reliability using the cheapest compact wireless laser multifunction printer from HP. Achieve professional quality and performance you expect.
Outstanding reliable quality without compromise
Easily print high-quality documents and with the reliability you expect from the leader in laser printing. Print directly from the start with a pre-installed cassette and an intuitive LED panel. HP Auto-On / Auto-Off technology helps to save energy.
Maximum productivity for business in compact format
Stay productive. Quickly and easily print, scan and copy documents with an efficient, compact laser multifunction printer designed to fit on small workspaces. This multifunction printer from HP provides high-quality results with HP toner cartridges.
The well-connected multifunction printer to match your work style
Provides consistent results that you can trust. Manage jobs from your mobile device, with or without a network. With mobile printing options, you can produce high-quality printing from virtually anywhere.
Outstanding, reliable quality without compromises
Time after time, count on documents with sharp black text from the industry leader in laser printing.Tackle tasks quickly and easily – with the simple control panel.Help save energy with HP Auto-On/Auto-Off Technology.Start printing right out of the box, using a preinstalled Original HP LaserJet toner cartridge. -
Big-time business productivity in a compact size
Stay productive with print speeds up to 18 pages per minute.Print, scan, and copy with a compact laser printer that accommodates tight workspaces.Get high-quality pages and the performance you can count on with Original HP toner cartridges. -
The well-connected MFP to match the way you work
Easily access, print, and share resources with Ethernet and wireless networking.Easily print from mobile devices with Android version 4.4 or later or Google Chrome operating systems.Print directly from your mobile device – without accessing the network.Print from virtually anywhere with HP ePrint.
- HP LaserJet Pro MFP M26nw - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 5000 pages
- Recommended Monthly Volume
- 100 - 1000 pages
- Max Copying Speed
- Up to 18 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 18 ppm
- Max Printing Resolution
- Up to 1200 dpi
- Scanning
- 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, cards, labels
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN
- Office Machine Features
- Security lock slot
- Power
- AC 230 V (50/60Hz)
- 42 cm x 26.6 cm x 25.4 cm
- 8.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - monochrome
- 5000 pages
- 100 - 1000 pages
- Interface
- USB 2.0, LAN
- Localisation
- Standard Memory
- 128 MB
Copying
- Max Copying Speed
- Up to 18 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 1200 dpi
- Up to 18 ppm
- Printer Drivers / Emulations
- PCLm, PCLms
- First Print Out Time B/W
- 9.2 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm), DL (210 x 99 mm)
- 150 sheets
- 100 sheets
- Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Wi-Fi Direct
- Software Included
- Drivers & Utilities
- Voltage Required
- 255 Watt
- Power Consumption Standby
- 2.2 Watt
- Power Consumption Sleep
- 1.4 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 500 pages
- EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55022:2010 CISPR 22:2008 Class B, EN 55024:2010
- Security Slot Type
- Kensington security slot
- ENERGY STAR Certified
- 42 cm
- 26.6 cm
- 25.4 cm
- 8.3 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 33.2 cm
- Shipping Height
- 35 cm
- Shipping Weight
- 10.3 kg
- Sound Emission
- 47 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
