HP LaserJet Pro MFP M227sdn
Quicklinx: CBKFWS00 Mfr#: G3Q74A#B19
HP Color LaserJet Pro MFP M277dw Colour Laser - Fax / copier / printer / scanner
  • Print, scan, copy, with one compact device
  • Fast two-sided printing built-in
  • Fast FPOT from ready mode
  • HP Auto-On/Auto-Off Technology
  • 6.9 cm touchscreen
  • Fast speeds, low energy use
    Print, scan, copy with a compact multifunction laser printer that fits into tight workspaces.Print at the pace of business with fast two-sided printing – first pages are ready in as fast as 7 seconds.Help save energy with HP Auto-On/Auto-Off Technology.Easily scan files directly to email, USB, and network folders with preloaded business apps.
  • Mobile printing made simple
    Print from iPhone and iPad with AirPrint , which automatically scales jobs to the correct paper size.Print with the ease of sending an email, right from a smartphone, tablet, or notebook, using HP ePrint.Send jobs from your smartphone, tablet, or PC to any company printer, using Google Cloud Print 2.0.
  • Manage company-wide printing with confidence
    Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.Identify new devices and gain insight into printing with HP Web Jetadmin remote discovery and monitoring.Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager.
  • HP quality – print after print
    Produce sharp text, bold blacks, and crisp graphics with precision black toner.Don't be fooled by cartridges that mimic Original HP. Help ensure you're getting the quality you paid for.Print over 2x more pages than standard cartridges, using optional Original HP high-yield toner cartridges.Get more pages than ever before, and track remaining pages to help ensure you get what you paid for.
HP LaserJet Pro MFP M227sdn - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2500 pages
Max Copying Speed
Up to 28 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 28 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper, light-weight paper, preprinted paper, postcards
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Bypass Feeder Capacity
10 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN
AirPrint Enabled
Office Machine Features
Instant-on Technology
AC 230 V (50/60Hz)
40.3 cm x 40.74 cm x 31.15 cm
9.4 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
Laser - monochrome
30000 pages
250 - 2500 pages
Display
2 lines
USB 2.0, LAN
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Up to 28 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy, collation copy
Printing
Max Printing Speed
Up to 28 ppm
Printer Drivers / Emulations
PCL 6, PCL 5c, PDF, PCLm
Image Enhancement Technology
HP FastRes 1200, HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
6.4 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, 76 x 187 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm)
250 sheets
Max Media Capacity
250 sheets
10 sheets
150 sheets
Input tray - 250 sheets size: 76 x 187 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets , ADF - 35 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 75 g/m² , Bypass tray - 10 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Speed Details
Printing: up to 47 ppm (A5) - B/W fast , Printing: up to 28 ppm (A4) - B/W normal , Printing: up to 6 ppm (A5) - B/W best , Scanning: up to 15 ppm (A4) - B/W normal , Copying: up to 28 ppm (A4) - B/W normal , Copying: up to 18 ppm (A4) - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
Apple Bonjour
Operating System Support
UNIX, Linux, Apple Mac OS X 10.9, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
475 Watt
Power Consumption Standby
4.5 Watt
Power Consumption Sleep
1 Watt
Consumables Included
1 x toner cartridge (black) - up to 1600 pages , 1 x drum - up to 23000 pages
ENERGY STAR Certified
Blue Angel Compliant
40.3 cm
40.74 cm
31.15 cm
9.4 kg
Shipping Width
49 cm
Shipping Depth
39.2 cm
Shipping Height
49 cm
Shipping Weight
13.2 kg
Ink (3)
CBKF HP 30A - black - original - LaserJet - toner cartridge ( CF230A ) In Stock £60.06
CBKF HP 32A Original Drum for LaserJet Pro In Stock £80.18
CBKF HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.86
Other bundles (4)
CBKF HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment In Stock £40.43
CBKF HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £47.70
CBKF HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment In Stock £21.99
CBKF HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF In Stock £27.47
