An efficient MFP for high-quality colour and productivity. Save time with Smart Tasks in HP Smart app, and print and scan from your phone. Get security essentials to help maintain privacy and control.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
Freedom to work anywhere
Get easy printing and scanning from your mobile device, with HP Smart – best-in-class mobile print app.Eliminate steps in repetitive tasks with customisable shortcuts, with Smart Tasks in HP Smart app.Organise documents 50% faster with Smart Tasks – first mobile print app that automates scanning tasks.Get notifications when printing, scanning, or copying from your mobile device, using HP Smart app. -
Trusted HP quality and performance
Get high-quality colour and peak printing performance with Original HP Toner cartridges with JetIntelligence.Breeze through tasks with a 35-page automatic document feeder.Get quick and easy copying and faxing directly at the control panel.Help save energy with HP Auto-On/Auto-Off Technology. -
Essential security
Security essentials to help maintain privacy and control, including basic encryption and password protection.Easily share resources – access and print with Ethernet networking.
- HP Color LaserJet Pro MFP M182n - multifunction printer - colour
- Multifunction printer
- Localisation
- Multilingual / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 150 - 1500 pages
- Max Copying Speed
- Up to 16 ppm (mono) / up to 16 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Scanning
- 1200 x 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Office Machine Features
- Scan to folder, scan to PDF
- Power
- AC 230 V (50/60Hz)
- 42 cm x 38 cm x 29.26 cm
- 15.7 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Printer Fonts
- TrueType x 84
- Laser - colour
- 30000 pages
- 150 - 1500 pages
- Display Features
- 7 segment LCD display with icons
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
- Hard Disk Drive
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, PCLm, PCLms, URF, PWG
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 11.8 sec
- First Print Out Time Colour
- 13.8 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 127 x 203 mm, 102 x 152 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 105 x 241 mm, 197 x 273 mm, 76 x 127 mm, 216 x 340 mm, 215.9 x 330.2 mm, 210 x 148 mm, 98 x 191 mm, 110 x 220 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm, 210 x 299 mm, 100 x 147 mm, 147 x 200 mm, 216 x 330 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 100 sheets
- Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 16 ppm (A4) - B/W (ISO) , Printing: up to 16 ppm (A4) - colour (ISO) , Printing: up to 27 ppm (A5) - B/W landscape , Printing: up to 21 ppm (A5) - colour landscape , Printing: up to 5 ppm (A5) - B/W portrait , Printing: up to 5 ppm (A5) - colour portrait , Copying: up to 16 ppm (A4) - B/W normal , Copying: up to 16 ppm (A4) - colour normal , Scanning: up to 15 ppm (A4) - B/W normal , Scanning: up to 8 ppm (A4) - colour normal
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- SSL, Apple Bonjour, TLS, IPv6 support, SNMP 3
- Operating System Support
- UNIX, Linux, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), macOS 10.12, macOS 10.13, macOS 10.14, macOS 10.15
- Software Included
- Drivers & Utilities
- Voltage Required
- 313 Watt
- Power Consumption Standby
- 7.4 Watt
- Power Consumption Sleep
- 0.7 Watt
- Warm-Up Time
- 59 sec
- First Copy Out Time B/W
- 12.2 sec
- First Copy Out Time Colour
- 17.9 sec
- TUV GS, EAC, EN 62479:2010, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55024:2010+A1:2015, EN 55032:2012, IEC/EN 60825-1:2014 Class 1, CISPR 32:2012, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, Mercury-free, DE-UZ 205, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 42 cm
- 38 cm
- 29.26 cm
- 15.7 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 37.9 cm
- Shipping Height
- 46.6 cm
- Shipping Weight
- 18.4 kg
- Sound Emission
- 16 dBA (idle) / 49 dBA (operating)
- 10 °C
- 32.5 °C
- 30 - 70%
Ink (5)
HP 216A Black Original LaserJet Toner Cartridge | In Stock | £39.14 |
HP 216A Cyan Original LaserJet Toner Cartridge | In Stock | £42.21 |
HP 216A Yellow Original LaserJet Toner Cartridge | In Stock | £42.21 |
HP 216A Magenta Original LaserJet Toner Cartridge | In Stock | £42.21 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.44 |
Other bundles (4)
HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment | In Stock | £43.74 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment | In Stock | £54.67 |
HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment | In Stock | £21.87 |
HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF | In Stock | £27.33 |
