Winning in business means working smarter. The HP LaserJet Pro M404 printer is designed to let you focus your time where it’s most effective-helping to grow your business and staying ahead of the competition.
Built to keep you – and your business – moving forward
Help decrease the amount of paper used in the office by printing on both sides of the page.Print wirelessly even without the network. Stay connected with dual band Wi-Fi and Wi-Fi direct.Print effortlessly from any device, virtually anywhere, to any HP printer – securely through the cloud. -
Best-in-class security – detect and stop attacks
A suite of embedded security features help protect your printer from being an entry point for attacks.Help secure confidential information with optional PIN/Pull printing to retrieve print jobs.Optional HP JetAdvantage Security Manager lets you set configuration.Thwart potential attacks and take immediate action with instant notification of security issues. -
Simply designed to uncomplicate your day
Set up this printer fast and easily manage device settings to help increase overall printing efficiency.Make the most of your office space with a printer that conveniently fits into your workstyle.Work without delays or messes, with cartridges featuring auto seal removal. -
Sustainability is smart business
Avoid frustrating reprints, wasted supplies, and service calls using Original HP toner cartridges.Help save paper right out of the box. The duplex print setting is set at default paper savings mode.Saves up to 18% energy over prior products.Help save energy with HP Auto-on/Auto-off technology.
- HP LaserJet Pro M404dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 8.56 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 38 ppm - black (ISO) - A4 (210 x 297 mm) , Up to 40 ppm - black (ISO) - ANSI A (Letter) (216 x 279 mm) , Up to 31 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 33 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 63 ppm - black landscape - A5 (148 x 210 mm) , Up to 14 ppm - black portrait - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 4800 x 600 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 256 MB (256 MB)
- Flash Memory Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF, URF, PWG
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, light-weight paper, punched paper, preprinted paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- Printer Features
- Instant-on Technology
- Power
- AC 230V
- System Requirements
- Android, Apple iOS, Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1, Microsoft Windows Server 2008 R2 SP1 (64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Microsoft Windows 7 / 8 / 10, Apple macOS 10.12, Apple macOS 10.13, Apple macOS Mojave 10.14
- 1-year warranty
- 38.1 cm x 35.7 cm x 21.6 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 4800 x 600 dpi
- PostScript Support
- Standard
- Fonts Included
- 84 x TrueType
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 256 MB / 256 MB (max)
Flash Memory
- Flash Memory
- 256 MB (installed) / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 197 x 273 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm, 104.9 x 148.59 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 175 g/m²
- Media Weight (lbs)
- 16 lbs - 46.6 lbs
- 350 sheets
- Media Feeders
- Input tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m² - (16 lbs (min) - 46.6 lbs (max)) , Input tray: automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² - (16 lbs (min) - 32 lbs (max))
- Max Media Capacity
- 900 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 80000 pages
- 750 - 4000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP
- SSL, Apple Bonjour, TLS, 802.1x, EAP-TLS, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- FCC Class B certified, FCC Class A certified, Laser Class 1, FCC CFR47 Part 15, CECP, EN 62479:2010, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55024:2010+A1:2015, ICES-003 issue 6, CISPR 32:2012, EN 55032:2015 Class B, EN 60825-1:2014, EN 55032:2012 Class B, IEC 60825-1:2014, CISPR 32:2015, RAL-UZ 205, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 495 Watt
- Power Consumption Stand by
- 5.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year
- 15 °C
- 32.5 °C
- 10 - 80%
- Sound Emission (Idle)
- 15 dBA
- Sound Emission (Operating)
- 54 dBA
- 38.1 cm
- 35.7 cm
- 21.6 cm
- 8.56 kg
- Width (Shipping)
- 44.3 cm
- Depth (Shipping)
- 27.4 cm
- Height (Shipping)
- 46.4 cm
- Weight (Shipping)
- 10.5 kg
