HP LaserJet Pro M402M Mono Laser 40ppm Printer
Quicklinx: DZW0WS00 Mfr#: C5F96A#B19
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Shift your office into high gear with a powerful printer that doesn't keep you waiting. Print your first page and two-sided prints faster, and help keep your device, data, and documents safe - from boot up to shutdown.
  • Take control of printing and help save energy
    Use a suite of essential features to help you easily manage this power-conserving printer. It's built to fit right into your office space and work style.
  • Keep your business nimble when needs shift or opportunity strikes
    Ethernet capabilities help you stay connected and work with ease - from right where you are. Easily print from a variety of smartphones and tablets - generally no setup or apps required.
HP LaserJet Pro M402m - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
8.58 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 38 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 40 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 30 ipm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 32 ipm - B/W duplex (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 14 ppm - B/W (ISO/IEC 24734) - A5 (148 x 210 mm) , Up to 63 ppm - B/W (ISO/IEC 24734) - A5 (148 x 210 mm)
Max Resolution (B&W)
4800 x 600 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
1200 MHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5, PostScript 3, PCL 6, PDF 1.7, PCLm, URF, PWG
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, paper, light-weight paper, punched paper, preprinted paper
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
Printer Features
Instant-on Technology, Auto Power On, Auto Power Off, JetIntelligence Cartridge Technology
AC 230V
UNIX, Linux, Red Hat Linux 8.0, Slackware Linux 9.1, Microsoft Windows Vista (32-bit versions), Red Hat Enterprise Linux 5, Novell Open Enterprise Server 2.0, Microsoft Windows XP SP3, Android, Linux Linpus 9.4, Ubuntu 10.04, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Mandriva Linux 2010, Apple iOS, Linux Linpus 9.5, Ubuntu 11.10, Ubuntu 12.04, Windows 8 (32/64 bits), openSUSE 12.2, Apple MacOS X 10.8, Red Hat Linux 9.0, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Debian Linux 6.0.7, Apple MacOS X 10.9, Red Hat Fedora 18, Mandriva Linux 2011, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Debian Linux 6.0.5, Ubuntu 14.04, Red Hat Fedora 19, Debian Linux 6.0, Red Hat Enterprise Linux 7, Linux Mint 14, Linux Mint 15, Debian Linux 7.4, Apple MacOS X 10.10, Debian Linux 7.0, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.1 or later, Debian Linux 7.1 or later, PCLinuxOS 2006 or later, Slackware Linux 9.0 or later, gOS, SUSE Linux 12.2, SUSE Linux 12.3, SUSE Linux 13.1, IGOS 1.0
1-year warranty
38.1 cm x 35.7 cm x 21.6 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
4800 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
Language Simulation
Fonts Included
84 x TrueType
Printer Features
Media Handling
1200 MHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 197 x 273 mm, 76.2 x 127 mm, 215.9 x 355.6 mm, 216 x 340 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm, 104.9 x 148.59 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm)
Media Weight
60 g/m² - 175 g/m²
350 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
900 sheets
Output Trays Capacity
150 sheets
Duty Cycle
100000 pages
750 - 4000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, IPP, HTTP, HTTPS, SLP
Security Protocols & Features
SSL, Apple Bonjour, TLS, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
1 x USB cable
Consumables Included
1 x toner cartridge (black)
Security lock slot (cable lock sold separately), LED indicator, password security, collation, Mobile Printing
FCC Class B certified, ICES-003, Laser Class 1, FCC CFR47 Part 15, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60825-1:2001, IEC 62479, IEC 60825-1:2007, EN 62479:2010, GB 4943-2011, GB 17625.1-2012, EN55022:2010 Class B, EN 55024:2010, CISPR 22:2008, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+AC:2013, IEC 60950-1:2005 + A1:2009
Security Slot Type
Kensington security slot
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
591 Watt
Power Consumption Stand by
6.1 Watt
Power Consumption Sleep
2.8 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows Vista/7/8/8.1/10 - 1 GHz - RAM 1 GB - HD 400 MB , MacOS X 10.8/10.9/10.10 - HD 1 GB
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 1 year
15 °C
32.5 °C
30 - 70% (non-condensing)
Sound Emission (Operating)
54 dBA
38.1 cm
35.7 cm
21.6 cm
8.58 kg
Width (Shipping)
44.3 cm
Depth (Shipping)
27.4 cm
Height (Shipping)
46.4 cm
Weight (Shipping)
11.36 kg
