Print, copy and scan with this easy-to-use, smallest-in-class colour MFP that offers two-sided printing and wireless connectivity, and helps you finish tasks fast. Original HP Toner cartridges with JetIntelligence produce more pages.
- HP Color LaserJet Pro MFP M377dw - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Speed
- Up to 24 ppm (mono) / up to 24 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 38400 x 600 dpi (mono) / up to 38400 x 600 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Display
- 4.3"
- Original Size
- 48.8 x 48.8 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, photo paper, bond paper, glossy paper, punched paper, preprinted paper, postcards
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, save to network folder, scan to Cloud, Instant-on Technology, Instant-on Copy
- Power
- AC 230 V (50Hz)
- 41.6 cm x 47.2 cm x 40 cm
- 23.2 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Laser - colour
- 50000 pages
- 750 - 4000 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Fit to page, ID Card Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, PCLm, URF
- Image Enhancement Technology
- HP ImageREt 3600, Pantone Calibrated
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 30-bit
Document & Media Handling
- Min Original Size
- 48.8 x 48.8 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, Folio (216 x 330 mm), 100 x 148 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76 x 127 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 300 sheets
- 850 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m²
- Speed Details
- Printing: up to 24 ppm (A4) - B/W normal , Printing: up to 24 ppm (A4) - colour normal , Printing: up to 25 ppm (Letter A) - B/W , Printing: up to 25 ppm (Letter A) - colour , Printing: up to 19 ipm (A4) - B/W duplex , Printing: up to 19 ipm (A4) - colour duplex , Printing: up to 20 ipm (Letter A) - B/W duplex , Printing: up to 20 ipm (Letter A) - colour duplex , Copying: up to 24 ppm (A4) - B/W normal , Copying: up to 24 ppm (A4) - colour normal , Copying: up to 25 ppm (Letter A) - B/W , Copying: up to 25 ppm (Letter A) - colour , Scanning: up to 26 ppm (A4) - B/W normal , Scanning: up to 21 ppm (A4) - colour normal , Scanning: up to 26 ppm (Letter A) - B/W normal , Scanning: up to 21 ppm (Letter A) - colour normal
- 2 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Operating System Support
- Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 SP2 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Novell NetWare 6.5 SP8, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 2
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 560 Watt
- Power Consumption Standby
- 19 Watt
- Power Consumption Sleep
- 2.4 Watt
- Included Accessories
- USB cable
- Consumables Included
- 1 x Cartridge (black) - up to 2300 pages , 1 x Cartridge (cyan) - up to 1200 pages , 1 x Cartridge (magenta) - up to 1200 pages , 1 x Cartridge (yellow) - up to 1200 pages
- FCC Class B certified, cUL, GS, CB, EMC, Laser Class 1, FCC CFR47 Part 15, EN 61000-3-3:2008, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 62479:2010, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, CoC, EN55022:2010 Class B, EN 55024:2010, CISPR 22:2008, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013, EN 61000-3-2:2006 + A1:2009 + A2:2009
- ENERGY STAR Certified
- Blue Angel Compliant
- 41.6 cm
- 47.2 cm
- 40 cm
- 23.2 kg
- Shipping Weight
- 26.8 kg
- Sound Emission
- 30 dBA (idle) / 51 dBA (operating)
- 15 °C
- 30 °C
- 10 - 90% (non-condensing)
