This black-and-white desktop MFP increases productivity with automatic two-sided printing, built-in networking, security features and mobile printing options.
Get an MFP designed for productivity
Save time and help reduce paper costs, using reliable automatic two-sided printing.Just start printing, quick and easy – with the simple control panel.Reduce employee time at the MFP, using the automatic document feeder.Put this MFP to work, right out of the box – full-capacity, 1,500-page toner cartridge included. -
Connect and protect your MFP
Easily manage settings and help keep data secure with built-in features.Easily share this MFP using Ethernet connectivity.Connect via USB and access tools at your PC to manage your MFP and supplies. -
Reduce your impact
Help save energy with HP Auto-On/Auto-Off Technology.Print reliably on a wide range of paper types – including office papers as light as 60 g/m2.Count on easy, free cartridge recycling through HP Planet Partners.Conserve resources with an MFP that's ENERGY STAR qualified and Blue Angel compliant.
- HP LaserJet Pro MFP M225dn - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 8000 pages
- Recommended Monthly Volume
- 500 - 2000 pages
- Max Copying Speed
- Up to 25 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 25 ppm
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper, light-weight paper, preprinted paper, postcards
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 10 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Instant-on Technology
- Power
- AC 230 V (50/60Hz)
- 44.25 cm x 28.87 cm x 37.13 cm
- 11.1 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - monochrome
- 8000 pages
- 500 - 2000 pages
- Display
- 2 lines
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Up to 25 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Collation copy
Printing
- Up to 25 ppm
- Printer Drivers / Emulations
- PCL 6, PCL 5c, PDF, PCLm
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 8 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 400 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, 76 x 187 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm)
- 250 sheets
- 250 sheets
- 10 sheets
- 100 sheets
- Input tray - 250 sheets size: 76 x 187 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets , ADF - 35 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 75 g/m² , Bypass tray - 10 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Speed Details
- Printing: up to 26 ppm (Letter A) , Copying: up to 26 ppm (Letter A) , Scanning: up to 15 ppm - B/W , Scanning: up to 6 ppm - colour , Copying: up to 26 ppm (Letter A) , Copying: up to 26 ppm (Letter A) , Copying: up to 25 ppm (A4) , Copying: up to 25 ppm (A4) , Printing: up to 25 ppm (A4) , Printing: up to 25 ppm (A4) , Scanning: up to 14 ppm (A4) - B/W normal , Scanning: up to 5 ppm (A4) - colour normal , Printing: up to 15 ipm (A4) - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A , 1 x modem - RJ-11
- Operating System Support
- MS Windows XP SP2 or later, MS Windows 7, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1, Windows 8.1, Apple Mac OS X 10.9, MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- 470 Watt
- Power Consumption Standby
- 4.5 Watt
- Included Accessories
- USB cable, phone cable, Ethernet cable
- Consumables Included
- 1 x toner cartridge (black) - up to 1500 pages
- FCC Class B certified, CISPR 22 Class B, GS, ICES-003, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, IEC 60950-1:2005, GB 17625.1-2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, EN 55024:2010
- ENERGY STAR Certified
- Blue Angel Compliant
- 44.25 cm
- 28.87 cm
- 37.13 cm
- 11.1 kg
- Shipping Width
- 59.7 cm
- Shipping Depth
- 39.7 cm
- Shipping Height
- 47.8 cm
- Shipping Weight
- 14.4 kg
- Sound Emission
- 50 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 90%
HP 83A Black Original LaserJet Toner Cartridge | In Stock | £55.93 |
