HP LaserJet Pro M130nw Multi-Function Printer
Quicklinx: CB9KWS00 Mfr#: G3Q58A#B19
HP LaserJet Pro M130nw Laser Multifunction Printer - Plain Paper Print - Copier/Printer/Scanner - 1200 x 1200 dpi Print - USB
  • Designed for efficiency
    Print, scan, and copy with HP's smallest LaserJet MFP – designed to fit into tight workspaces.Wait less. Print up to 22 pages per minute, with first pages ready in as fast as 7.3 seconds.Help save energy with HP Auto-On/Auto-Off Technology.Quickly capture two-sided documents in fewer steps.
  • Mobile printing made simple
    Print from iPhone and iPad with AirPrint , which automatically scales jobs to the correct paper size.Print with the ease of sending an email, right from a smartphone, tablet, or notebook, using HP ePrint.Print directly from your mobile device to your Wi-Fi Direct printer – without accessing the company network.Send jobs from your smartphone, tablet, or PC to any company printer, using Google Cloud Print 2.0.
  • HP quality – print after print
    Produce sharp text, bold blacks, and crisp graphics with precision black toner.Don't be fooled by alternatives that mimic Original HP. Help ensure you're getting the quality you paid for.Track toner levels with print gauge technology and produce the most prints possible.Quickly replace your cartridges, using auto seal removal and easy-open packaging.
HP LaserJet Pro MFP M130nw - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
10000 pages
Recommended Monthly Volume
150 - 1500 pages
Max Copying Speed
Up to 22 ppm
Max Copying Resolution
Up to 600 x 400 dpi
Max Printing Speed
Up to 22 ppm
Max Printing Resolution
Up to 1200 dpi
Scanning
1200 x 1200 dpi
Original Size
215.9 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, photo paper, vellum paper, card stock, postcards
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Instant-on Technology, HP Auto-On/Auto-Off Technology
AC 230 V (50/60Hz)
39.8 cm x 28.8 cm x 23.1 cm
6.8 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 pages
150 - 1500 pages
Display
2 lines
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Up to 22 ppm
Up to 600 x 400 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 1200 dpi
Max Printing Speed
Up to 22 ppm
Printer Drivers / Emulations
PCLms, URF, PWG
Image Enhancement Technology
HP FastRes 1200
First Print Out Time B/W
7.3 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
215.9 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm)
150 sheets
100 sheets
Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 22 ppm (A4) - B/W , Copying: up to 22 ppm (A4) - B/W , Printing: up to 23 ppm (Letter A) - B/W , Copying: up to 23 ppm (Letter A) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
255 Watt
Power Consumption Standby
4.2 Watt
Power Consumption Sleep
1 Watt
Consumables Included
1 x Cartridge (black) - up to 700 pages , 1 x drum - up to 12000 pages
EN 61000-3-3:2008, EN 55022:2010 CISPR 22:2008 Class B, Blue Angel Ecolabel, EN 55024:2010, EN 61000-3-2:2006 + A1:2009 + A2:2009
ENERGY STAR Certified
39.8 cm
28.8 cm
23.1 cm
6.8 kg
Shipping Width
49 cm
Shipping Depth
29.4 cm
Shipping Height
35 cm
Shipping Weight
9.1 kg
Sound Emission
51 dBA (operating)
15 °C
32.5 °C
30 - 70%
