HP LaserJet Pro M127fw Mono Laser Multifunction Printer
Price Drop
Limited Time Offer
Clearance
Quicklinx: 98T0WS00 Mfr#: CZ183A#B19
Easy to install, this affordable, full-featured MFP prints, copies, scans and faxes. Enable easy printing from smartphones, tablets and laptops – at work, home, or on the go – with wireless connectivity and mobile printing features.
Get it all done – with a wireless MFP that’s easy on your budget. Use the 3-inch colour touchscreen and simply tap to print, copy, scan and fax professional-quality documents.
Easily manage your MFP from the 7.6 cm (3-inch) colour touchscreen. Use the simple, intuitive control panel to set up projects easily and start printing right away. Finish projects fast – print documents at up to 20 ppm and get a first page out in as fast as 9.5 seconds with Instant-On Technology. Use the 35-page automatic document feeder to make the most of your time. Easily copy both sides of a two-sided ID or other small document onto the front of a single-page. Keep up with the pace of business with an MFP that prints, copies, faxes and scans.
Get right to printing, right away.
Spend less time at your MFP and more with your customers. Print, copy, and scan at high speeds that keep up with the pace of business. Help save energy with HP Instant-on Technology and HP Auto-On/Auto-Off Technology.
Enable easy printing from smartphones, tablets and laptops, at work, home or on the go.
Extend your printing reach. Easily set up, print, and share using Ethernet and wireless connectivity. Connect to your wireless printer in a snap using wireless direct printing. Print from your mobile device with built-in print capability or HP ePrint app and software. Print from virtually anywhere with AirPrint™.
  • On-the-go printing with HP ePrint
    Print photos, documents, and more when you're on the go, using HP ePrint.
  • Unleash your printing
    Print wirelessly from your mobile device without a Wi-Fi code or password.
  • Automatic document feeder
    Allows multiple pages to be copied or scanned at one time.
  • Scan to email
    Save time by sending scanned documents or photos directly from your printer to email recipients.
HP LaserJet Pro MFP M127fw - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
Scanning
1200 x 1200 dpi
Display
3.5"
Original Size
Legal (216 x 356 mm) (max)
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Embedded web browser
AC 230 V (50/60Hz)
42 cm x 36.5 cm x 30.9 cm
9.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
8000 pages
250 - 2000 pages
Display Diagonal Size
3.5"
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
128 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Printer Drivers / Emulations
PCL
Image Enhancement Technology
HP FastRes 1200
First Print Out Time B/W
9.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Transmission Memory Capacity
Up to 500 pages
Fax Printing Speed
Up to 20 ppm
PC Faxing
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling
Document & Media Handling
Max Original Size
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
150 sheets
100 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 21 ppm (Letter A) - B/W normal , Scanning: up to 7 ppm - B/W normal , Scanning: up to 5 ppm - colour normal , Copying: up to 21 ppm (Letter A) - B/W normal , Printing: up to 20 ppm (A4) - B/W normal , Copying: up to 20 ppm (A4) - B/W normal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
480 Watt
Power Consumption Standby
4.5 Watt
Power Consumption Sleep
1.1 Watt
USB cable, phone cable
Consumables Included
1 x toner cartridge (black) - up to 700 pages
UL, cUL, GS, ICES-003, EN55024, CISPR 22, EN55022 Class B, FCC Part 15.247, Directive 1999/5/EC, RSS-210, FCC Part 68, EMC, Laser Class 1, IEC 60950-1, FCC CFR47 Part 15 B, EN 60825-1, Directive 2004/108/EC, GB 9254-2008, Directive 2006/95/EC, EN 61000-3-3:2008, GB 17625.1-2003 EMC, EN 61000-3-2:2006+A1:2009+A2:2009, EN 300 328 V1.7.1, EN 60950-1:2006, NOM-151-SCTI-1999, IEC 60825-1:2007, EN 301 489-1, EN 301 489-17
ENERGY STAR Certified
Limited warranty - 1 year
42 cm
36.5 cm
30.9 cm
9.1 kg
Shipping Width
49.7 cm
Shipping Depth
39.8 cm
Shipping Height
35 cm
Shipping Weight
11.5 kg
Sound Emission
52 dBA (operating)
15 °C
32.5 °C
10 - 80%
98T0 HP 83A Black Original LaserJet Toner Cartridge In Stock £55.93
