HP Laserjet Pro M125nw Multifunction Printer
Quicklinx: 9H15WS00 Mfr#: CZ173A#B19
This affordable HP LaserJet Pro MFP is easy to install and delivers crisp, clear documents. Print, copy and scan with one, compact device that fits neatly into small office spaces.
  • Extend your printing reach
    Keep up with the pace of business: print and copy at high speeds of 20 ppm.Get a first page out in as fast as 9.5 sec.
  • Print on your terms
    Print from virtually anywhere – using your smartphone, tablet and PC – with Apple AirPrint .Easily print from mobile devices – without a network – using wireless direct printing.Connect your MFP directly to a PC or Netbook via the included Hi-Speed USB 2.0 port.
  • Handle the essentials
    Speed through document tasks and set the pace for success with an MFP that prints, copies and scans fast.Easily copy both sides of a two-sided ID or other small document onto the front of a single-page.Control made easy – just start printing right away with the easy-to-use, intuitive control panel.
HP LaserJet Pro MFP M125nw - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 400 x 600 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Scanning
1200 x 1200 dpi
Original Size
216 x 279 mm (max)
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
AC 230 V
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
1-year warranty
Printing Technology
Laser - monochrome
8000 pages
250 - 2000 pages
Display
2 lines
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
128 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 400 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Printer Drivers / Emulations
PCL
Image Enhancement Technology
HP FastRes 1200
First Print Out Time B/W
9.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 279 mm
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), 76 x 127 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
150 sheets
100 sheets
Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA, WPA2
Software Included
HP Toolbox
AC 230 V
USB cable
Consumables Included
1 x toner cartridge (black) - up to 700 pages
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 1 year
Shipping Width
49.7 cm
Shipping Depth
35 cm
Shipping Height
33.2 cm
Shipping Weight
10.3 kg
