HP LaserJet Pro M125a Mono Laser Multifunction Printer
Quicklinx: 9Y7NWS00 Mfr#: CZ172A#B19
This affordable HP LaserJet Pro MFP is easy to install and delivers crisp, clear documents. Print, copy and scan with one, compact device that fits neatly into small office spaces.
  • Handle the essentials
    Keep up with the pace of business: print and copy at high speeds of 20 ppm.Get a first page out in as fast as 9.5 sec.
  • Avoid wasted time with fast printing and easy installation
    Reduce energy use with Instant-on Technology.
  • Only the power you need
    Help reduce energy use when making copies with Instant-on Copy.Save energy – HP Auto-On/Auto-Off Technology turns your printer on when you need it and off when you don't.
HP LaserJet Pro MFP M125a - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 400 x 600 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
A4 (210 x 297 mm) (min) - A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0
Office Machine Features
Scan to folder, scan to application
AC 230 V (50/60Hz)
42 cm x 36.5 cm x 25.4 cm
8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - monochrome
8000 pages
250 - 2000 pages
USB 2.0
Standard Memory
128 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 400 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Printer Drivers / Emulations
PCLm, PCLms
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
9.5 sec
Scanning
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
A4 (210 x 297 mm)
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
150 sheets
100 sheets
Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W , Printing: up to 21 ppm (Letter A) - B/W , Copying: up to 20 ppm - B/W
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
Linux, MS Windows XP SP2 or later, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6.8 or later, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, MS Windows XP 64-bit Edition SP2 or later, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows Server 2003 x64 Edition SP1 or later, MS Windows Server 2008 Enterprise, MS Windows Server 2008 Standard, MS Windows Server 2008 (32/64-bits)
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
465 Watt
Power Consumption Standby
2.2 Watt
Power Consumption Sleep
0.7 Watt
Consumables Included
1 x toner cartridge (black) - up to 700 pages
FCC Class B certified, UL, CISPR 22 Class B, cUL, GS, ICES-003, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, GB 17625.1, LVD, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, IEC 60950-1:2005, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
ENERGY STAR Certified
42 cm
36.5 cm
25.4 cm
8 kg
Shipping Width
49.7 cm
Shipping Depth
35 cm
Shipping Height
33.2 cm
Shipping Weight
10.3 kg
Sound Emission
48 dBA (operating)
15 °C
32.5 °C
10 - 80%
9Y7N HP 83A Black Original LaserJet Toner Cartridge In Stock £56.07
