This affordable HP LaserJet Pro MFP is easy to install and delivers crisp, clear documents. Print, copy and scan with one, compact device that fits neatly into small office spaces.
Handle the essentials
Keep up with the pace of business: print and copy at high speeds of 20 ppm.Get a first page out in as fast as 9.5 sec. -
Avoid wasted time with fast printing and easy installation
Reduce energy use with Instant-on Technology. -
Only the power you need
Help reduce energy use when making copies with Instant-on Copy.Save energy – HP Auto-On/Auto-Off Technology turns your printer on when you need it and off when you don't.
- HP LaserJet Pro MFP M125a - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 8000 pages
- Recommended Monthly Volume
- 250 - 2000 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 400 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 600 x 600 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- A4 (210 x 297 mm) (min) - A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0
- Office Machine Features
- Scan to folder, scan to application
- Power
- AC 230 V (50/60Hz)
- 42 cm x 36.5 cm x 25.4 cm
- 8 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Laser - monochrome
- 8000 pages
- 250 - 2000 pages
- Interface
- USB 2.0
- Localisation
- Standard Memory
- 128 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Up to 20 ppm
- Printer Drivers / Emulations
- PCLm, PCLms
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 9.5 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- A4 (210 x 297 mm)
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
- 150 sheets
- 100 sheets
- Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Printing: up to 21 ppm (Letter A) - B/W , Copying: up to 20 ppm - B/W
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- Linux, MS Windows XP SP2 or later, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6.8 or later, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, MS Windows XP 64-bit Edition SP2 or later, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows Server 2003 x64 Edition SP1 or later, MS Windows Server 2008 Enterprise, MS Windows Server 2008 Standard, MS Windows Server 2008 (32/64-bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- 465 Watt
- Power Consumption Standby
- 2.2 Watt
- Power Consumption Sleep
- 0.7 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- FCC Class B certified, UL, CISPR 22 Class B, cUL, GS, ICES-003, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, GB 17625.1, LVD, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, IEC 60950-1:2005, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- ENERGY STAR Certified
- 42 cm
- 36.5 cm
- 25.4 cm
- 8 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 35 cm
- Shipping Height
- 33.2 cm
- Shipping Weight
- 10.3 kg
- Sound Emission
- 48 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
HP 83A Black Original LaserJet Toner Cartridge | In Stock | £56.07 |
