HP LaserJet Pro 500 M570dw Colour Laser Multifunction Printer
SEE PRODUCT PAGE FOR OFFERS AND PROMOTIONS
Limited Time Offer
Quicklinx: 8FJCWS00 Mfr#: CZ272A#B19
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Laser
£768.87 ex VAT
£922.64 inc VAT
Finish jobs faster, produce high-impact colour, and get set up and connected quickly. Print from your smartphone or tablet with HP ePrint. Easily conserve resources and recycle used cartridges.
  • Expand your performance potential
    Increase productivity and finish scanning jobs faster with single-pass, dual-head scanning.Print documents at up to 30 pages per minute. Rely on a robust recommended monthly page volume of 1500 to 4000 pages.Convert hard copies to digital files for easy distribution and storage, and make flawless copies.Easily handle jobs to stay productive, using the 50-sheet document feeder and automatic two-sided printing.
  • Show off with powerful colour
    Simplify workflows: access, store and print business content quickly with an 8.89 cm (3.5-inch) colour touchscreen.Make maximum impact – optimise colour settings and get vivid results with incredible resolution.Produce top-notch marketing materials in the office – on a broad range of media and in a variety of sizes.Start working fast with preinstalled cartridges. Get better value with optional high-capacity cartridges.
  • Enjoy fast, easy set-up and stay connected
    Use HP Auto Wireless Connect to configure networking without wires.Print from your smartphone or tablet with HP ePrint. Easily send prints from devices without a network.Use resources more efficiently with wireless and 10/100/1000T Gigabit Ethernet networking – access, print, and share.Proactively manage this MFP, using HP Web Jetadmin to monitor office printing and device status remotely.
  • Help reduce your environmental impact
    Help save energy with HP Auto-On/Auto-Off Technology, Instant-on Copy, and Instant-on Technology.Conserve resources and save paper – use automatic two-sided printing.Get centralised, easy access to custom energy-saving options and printer settings with HP EcoSMART Console.Reduce your impact – easily recycle Original HP LaserJet toner cartridges through HP Planet Partners.
HP LaserJet Pro MFP M570dw - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
75000 impressions
Recommended Monthly Volume
1500 - 4000 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network, HP Auto Wireless Connect, scan to Cloud
AC 230 V (50Hz)
51.5 cm x 50 cm x 53.8 cm
40.8 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
75000 impressions
1500 - 4000 pages
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB 256 MB
Max Supported Memory
256 MB 256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.7
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
First Print Out Time B/W
10.5 sec
First Print Out Time Colour
10.5 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 250 pages
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
120 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), B6 (125 x 176 mm), 76 x 127 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
350 sheets
Max Media Capacity
850 sheets
100 sheets
250 sheets
Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: A5 (148 x 210 mm) - 216 x 297 mm weight: 60 g/m² - 220 g/m² , ADF - 50 sheets - Legal (216 x 356 mm) , Output tray - 250 sheets
Speed Details
Printing: up to 30 ppm - B/W normal , Printing: up to 30 ppm - colour normal , Copying: up to 30 ppm - B/W normal , Copying: up to 30 ppm - colour normal , Scanning: up to 19.5 ppm (A4) - B/W normal , Scanning: up to 14 ppm (A4) - colour normal
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Security Protocols & Features
SSL, Apple Bonjour, 802.1x, WPA2-PSK, WPS
Operating System Support
MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Sun Solaris 8, Sun Solaris 9, MS Windows 7, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, MS Windows Server 2008, Apple Mac OS X 10.6, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Linux Linpus Desktop 9.4, Linux Linpus Desktop 9.5, Ubuntu Linux 8.04.1 LTS, Ubuntu Linux 8.04.2 LTS, Apple Mac OS X 10.7, Debian Linux 5.0, MS Windows Server 2003 SP3 or later, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Windows 8 64-bit
Software Included
Drivers & Utilities
AC 230 V (50Hz)
605 Watt
Power Consumption Standby
52 Watt
Power Consumption Sleep
8.1 Watt
USB cable, phone cable
Consumables Included
1 x Cartridge (black) - up to 5500 pages , 1 x Cartridge (yellow/cyan/magenta) - up to 6000 pages
CISPR 22 Class A, GS, EN55024, EN55022 Class A, EMC, Laser Class 1, IEC 60950-1, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1, GB 17625.1, LVD, EN 61000-3-2:2006, EN 61000-3-3:2008
ENERGY STAR Certified
Limited warranty - 1 year - on-site - response time: next business day
51.5 cm
50 cm
53.8 cm
40.8 kg
Shipping Width
73.3 cm
Shipping Depth
64.4 cm
Shipping Height
73 cm
Shipping Weight
45.9 kg
Sound Emission
52 dBA (operating)
10 °C
30 °C
10 - 70%
8FJC HP 507A Black Original LaserJet Toner Cartridge In Stock £116.79
8FJC HP 507A Cyan Original LaserJet Toner Cartridge In Stock £184.70
8FJC HP 507A Yellow Original LaserJet Toner Cartridge In Stock £179.52
8FJC HP 507A Magenta Original LaserJet Toner Cartridge In Stock £179.52
8FJC HP 507X High Yield Black Original LaserJet Toner Cartridge In Stock £162.12
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: 750 - 1000
